Josh66
- Joined
- Oct 31, 2007
- Messages
- 14,593
- Reaction score
- 1,239
- Location
- Cedar Hill, Texas
- Can others edit my Photos
- Photos NOT OK to edit
OK, so I decided not to derail this thread any further...
I was going to reply to this post, but thought a new thread would be more appropriate.
Now, on all of my lenses, the red dot for IR focus reaches infinity before the 'normal' focus mark. That means that you would never have to go past infinity to focus IR at infinity.
pgriz says that it's to allow for temperature variances (and cites the manual to a lens). I said that it's to allow the AF mechanism to overshoot it and come back to prevent damage (just seems right - I don't have any references).
So, we have 3 theories - (1) IR focus; (2) Temperature; (3) Built in 'slop' to prevent damage.
Since IR reaches focus before visible light, there is no reason to go past infinity in IR. The temperature differences seem kind of small to me (relatively) for it to affect a lens to that degree. The 'slop' theory sounds good to me, but I can't back it up with anything.
So, the question is - why will some lenses allow you to focus past infinity? Also, is there any situation (other than those mentioned) where it would be desirable to focus past infinity?
I don't think it has anything at all to do with temperature. And it's not IR either. IR focus is on the near side of infinity, not the far side (look at your lenses if you don't believe me).And all these years I thought is was because infrared has a different focus point than visible light.
My theory is that the over-travel allows the AF mechanism to overshoot it a little, then come back. (To avoid damage from the lens slamming into infinity.)
Just a couple observations - every AF lens I have used will go past infinity. Every MF lens I have used has a hard stop at infinity.
edit
In case anybody is wondering about the different focus point for IR - that's what the red dot is for. When you're shooting IR, use the red dot instead of the line.
And if that still doesn't make any sense to you, you probably don't have any lenses that have distance scales on them.
I recall my 35mm film camera lenses saying in the instructions that's the reason the lens goes past infinity. And none of them were AF.
