Infra red film...Infra red digital?
Discussion in 'Beyond the Basics' started by Artemis, Feb 17, 2005.
  1. Artemis
    Artemis Just Punked Himself
    May 16, 2004
    5,313
    43
    England! w000t!
    On practical photography there was a thing about turning digital images to infre red ones...
    I was curious...how can I do it with my 300D? :)
  2. Scurra
    Scurra TPF Noob!
    Aug 19, 2004
    1,159
    7
    Kent UK
    I think it's something that is done in PS Arty I read a similar piece in Photography Monthly..
  3. voodoocat
    voodoocat ))<>(( Supporting Member
    May 15, 2003
    5,277
    17
    Gilbert, AZ
    You can do it with PS but it's not like real infrared. It only simulates it. You can get an infrared filter like the Hoya R72. Now with the drebel a lot of lenses will have a hot spot in the center of the frame. I'm not sure which ones though.
  4. Artemis
    May 16, 2004
    5,313
    43
    England! w000t!
    COuld you show me how to do it in PS? :p...and later I may get the filter :D
  5. Unimaxium
    Unimaxium TPF Noob!
    Nov 13, 2004
    2,689
    22
    Northeastern University, originally from Philly
    OOh this reminds me, I want to pick up the latest issue of PP in a bookstore. I bought last month's issue and liked it a lot. :)
  6. Digital Matt
    Jan 30, 2004
    5,346
    66
    Santa Barbara, CA
    In PS, duplicate your background layer, invert it, set its' blend mode to color, then make a channel mixer adjustment layer, check monochrome, and put your blue channel at 100%, and the other two to 0.
    I would highly recommend buying a Hoya R72 filter however. The results are much nicer.
    I have a list of Canon AF lenses and which ones give a hotspot and which don't. It's a journal entry on my DA page, and you can find it here: http://mperko.deviantart.com/journal/4289193/
  7. ferny
    ferny TPF Noob!
    Aug 31, 2004
    8,114
    64
  8. Artemis
    May 16, 2004
    5,313
    43
    England! w000t!
  9. spike000
    spike000 TPF Noob!
    Feb 13, 2005
    70
    London, UK
    One thing to look out for if you use film.
    Your 300v has an infra-red light on the inside used to assist with auto wind of the film.
    It will mark dots on the film and be quite destructive if you leave the camera on or the film in for any length of time.
    Spike
  10. Artemis
    May 16, 2004
    5,313
    43
    England! w000t!
    I know....but if I was carefull...would the film come out ok? :S
  11. Digital Matt
    Jan 30, 2004
    5,346
    66
    Santa Barbara, CA
    Arty, it helps to understand a bit more about infrared light, and how it is reflected. Not all things will photograph well in infrared, and similarly, not all photos will look good after the ps trick. Typically, outdoor scenes in bright light with lots of green vegetation and a nice deep blue and cloudy sky work the best.
    Here is an example:
    [​IMG]
  12. Artemis
    May 16, 2004
    5,313
    43
    England! w000t!
    hehe thanks, and thats a great picture! Ill show you what I got after doing the p.s. trick :)
