infrared compatible
Discussion in 'Photography Equipment & Products' started by Fuschia, Jul 26, 2003.
  1. Fuschia
    Fuschia TPF Noob!
    Jul 26, 2003
    27
    Toronto
    Hey everyone, this is my first post! Exciting! hehehe
    I already have an SLR, but its so old (older than I am!), and generally lacking, that I've decided to buy meself a new spiffy one. The one feature I'm looking for is compatibility with infrared film. Does anyone know of any good (but not overly expensive) infrared-film compatible SLRs? Thanks a bunch in advance!
  2. photobug
    photobug TPF Noob!
    Apr 19, 2003
    1,562
    5
    Pasco, WA
    Welcome to the board!
    Rather than muddy the water I'll just post this link that explains the ins and outs of IR photos.
    hth
    Jim
  3. enigma
    enigma TPF Noob!
    Jun 13, 2003
    86
    as far as i know all slr cameras will take 35mm IR film. Let me know if I am wrong though.
  4. Fuschia
    Fuschia TPF Noob!
    Jul 26, 2003
    27
    Toronto
    there are some (I think the canon eos series) that fog high speed infrared film, I think.
  5. motcon
    motcon TPF Noob!
    Jul 18, 2003
    1,410
    usa. soon to be a euro boy.
    you are correct, Fuschia; some of the canon bodies (elan II, the a2, and the eos-3) and nikon bodies (n65 and n80) use an infrared sensor in their backs and this fogs ir film badly. some have had some successes using different types of ir film, but it is a probability that there will be fogging.
    what features are you wanting in a camera? this will help narrow down suggestions. to start, i know that the nikon f80 and f100 are just fine. i also shoot a pentax p3 and a konica tc (both older, manual bodies) and are fine.
  6. Fuschia
    Fuschia TPF Noob!
    Jul 26, 2003
    27
    Toronto
    I was looking for some pretty specific stuff, heh.
    -infrared capability (duh)
    -preferrably manual focus, or AF with manual override
    -spot metering
    -operates without batteries (yeah, thats a long shot)
    -easy for someone with glasses to use.
    Other than that, just a manual SLR that would be appropriate for an 'advanced amateur', without too too many fantastic, confusing features.
    I've been doing research, and the more I try to narrow down my choices, the more choices I seem to have...its very daunting :?
  7. motcon
    motcon TPF Noob!
    Jul 18, 2003
    1,410
    well, if you've been doing research why don't you post some of the cameras that interest you?
  8. Fuschia
    Fuschia TPF Noob!
    Jul 26, 2003
    27
    Toronto
    here are a few I've been looking at:
    Nikon N80/N75
    Olympus OM 2000
    Minolta X-700
    Canon Rebel 2000/Ti
    Pentax *ist
    Pentax K1000
    Canon Elan 7
  9. Bob_McBob
    Bob_McBob TPF Noob!
    Jul 28, 2003
    160
    Ontario, Canada
    The problem with cameras that have internal drives to advance film (ie most modern SLRs) is that many of them use an infrared sensor to count sprocket holes as the film advances. This means that one edge of the film is continuously exposed to the sensor as it's run through the camera, so IR film will be fogged on that edge. I can't tell you how bad it is with all of these models (and in fact, it seems that the degree of severity even varies by individual body with some of them). I think you can safely say that so long as the light seals are intact, most manual models like the K1000 shouldn't have problems with IR film, but don't quote me on that! I'm 100% certain that the N80 has an infrared sprocket counter, and the same probably goes for the N75. Almost every camera in Canon's current line-up has problems with IR film, too. So, the Rebel 2000 and Elan 7 will certainly fog it. As far as I know, the only current EOS model that won't is the EOS 1V, which is a tad expensive ;).
    As to the other part of your requirements... The N80 can do spot metering, as can the N75. With Canon, you have to go all the way up to the EOS 3 to get true spot metering, so neither of your choices have it. The Elan 7 has some sort of partial metering system, but it's not a true spot. The K1000 and X700 use center weighted metering, and the OM 2000 does that as well as spot. I'm sure you can find spec sheets for all these cameras with Google.
    Hopefully some other users can fill in the gaps here! As to fitting all your requirements, the only camera that comes to mind right now is the F-1N, oddly enough. It should work with infrared film, is manual focus, has spot metering with a focusing screen change, works at almost all shutter speeds without batteries, and should be easy enough to use with glasses. Built like a tank to boot :). Hope this helps.
    Edit: I just wanted to add this: if you're interested in an autofocus body that you'll also use for manual focus a lot of the time, Canon's USM lenses with full time manual focusing are very attractive. Not only are they almost completely silent when autofocusing, but you can grab the focusing ring at any time and touch up the focus, without having to flip any switches on the body. This is probably the main reason why I prefer the Elan 7 over the N80... when the N80 autofocuses, it makes a lot of noise! After using the USM lenses, it feels very awkward to go back to the system that most Nikkor lenses/Nikon bodies use.
  10. motcon
    motcon TPF Noob!
    Jul 18, 2003
    1,410
    i'm out to lunch on olympus and minolta.
    Bob is pretty much 'on' with his material above. nikon n60, 75, and 80 all use ir sensors.
    the only sticking point w/the f-1n is that in order to change focusing areas you have to change the focusing screen and they do easily damage.
    i neglected to ask the obvious: what is your budget?
  11. Fuschia
    Fuschia TPF Noob!
    Jul 26, 2003
    27
    Toronto
    wow, so many helpful answers! thanks everyone!
    Motcon, my budget is pretty decent, up to 1000$ cdn, but I want to spend as little of it as possible. Hopefully, I can find a good camera, possibly secondhand, and then spend some money on extras. I already have an old Zenit 11 thats all manual (w/a selenium meter), so I was kindof shooting for an autofocus that has manual override.
  12. Bob_McBob
    Bob_McBob TPF Noob!
    Jul 28, 2003
    160
    Ontario, Canada
    I just wanted to add that I'm told that many of the OM series don't do very well with infrared film because of dimpling on their pressure plates. Because Kodak HIE specifically has no anti-halation layer, the light bounces off the pressure plate, and you see a lovely dimple pattern on the negative because of the reflected light. I'm no Oly expert, so I can't be more specific on the models. Any Olympus buffs here? :)
