Infrared is FUN!
Discussion in 'Alternative Techniques & Photo Gallery' started by Double H, Nov 21, 2007.
  1. Double H
    Double H TPF Noob!
    Nov 12, 2007
    550
    24
    Around the corner from the Turkey Hill, PA
    [​IMG]
    [​IMG]
    [​IMG]
    4
    [​IMG]
    5
    [​IMG]
  2. doobs
    doobs TPF Noob!
    Oct 7, 2007
    566
    Sacramento, CA
    Great job! HIE?
  3. Double H
    Double H TPF Noob!
    Nov 12, 2007
    550
    24
    No, but thanks! These were shot with a Fuji S2 Pro + a Hoya R72 IR filter on a Nikkor lens
  4. cameramike
    cameramike TPF Noob!
    Sep 4, 2007
    875
    NJ
    awesome shots!
  5. itsallinphilly5515
    itsallinphilly5515 TPF Noob!
    Nov 20, 2007
    13
    Philadelphia
    Can you please explain how infrared is done? Please and thank you
  6. doobs
    doobs TPF Noob!
    Oct 7, 2007
    566
    Sacramento, CA
    You get infrared film and a red filter and shoot!
  7. nealjpage
    nealjpage multi format master in a film geek package
    Sep 16, 2005
    3,479
    Oregon
    I haven't shot any, either, but try searching the forums a bit. There's a lot of info out there. I know Terri and a few others get into it. They'll help you out.
  8. terri
    terri Administrator Staff Member Supporting Member
    Sep 2, 2003
    27,373
    2,838
    In the mental ward of this forum
    Well, my favorite IR film is Kodak HIE which is being D/C next month - it's still easy to find, but I'm not certain this was an analog question. ;) The OP uses digital and that's a foreign language to me. This thread is actually mis-posted, since the Alt Forum is geared towards film-based photography; I just let it slide.
  9. doobs
    doobs TPF Noob!
    Oct 7, 2007
    566
    Sacramento, CA
    You can do digital IR?
  10. terri
    Sep 2, 2003
    27,373
    2,838
    So they say. :mrgreen: I believe that is what is posted in this thread.
  11. doobs
    doobs TPF Noob!
    Oct 7, 2007
    566
    Sacramento, CA
    You know, I just googled this and tried it and if you point a remote at your camera and press a button on the remote, and see a white flashing light you can take infrared pictures. So I grabbed an infrared filter and tried it, but when I converted to B+W in PS, it didn't work. :/
  12. Helen B
    Helen B TPF Noob!
    Sep 16, 2007
    3,296
    465
    Hell's Kitchen, New York
    Doobs,
    It's easier using digital, in may ways. Sensors are inherently sensitive to infrared, and it is usually a nuisance rather than a benefit. The RGB filters mostly pass infrared - even the green and blue ones - so there needs to be another filter over the sensor to stop the infrared radiation but allow the light to pass.
    This is not easy to do perfectly at all angles of incidence, so some infrared may get through. It varies from camera to camera. It's rather like light meters - many of them read infrared radiation to some extent, as well as the light that they are meant to read.
    Sony 'Nightshot' video cameras allow the filter to be moved out of the way, so that when Nightshot is engaged the filter is out of the way, and infrared sources ("black lights") can be used. The Nightswitch mode also forces the camera to maximum exposure, to deter the use of it during the day - not all clothing is opaque to infrared, and Sony do not like being associated with a device that can 'see through' clothing.
    As you have already discovered, some cameras can be used for infrared without modification. You can also have the infrared-reducing filter removed from the sensor, or you can buy a camera with no filter there in the first place - such as the Fuji IS-1. The IS-1 has an electronic viewfinder - which is a useful feature for an infrared camera.
    The sensitivity of sensors to infrared has a small downside for colour work. Colour infrared film is only sensitive to infrared in the blue-sensitive layer. Therefore if you cut blue light with a yellow filter the film then has layers sensitive to green, red and infrared. The false colour can then be created from these three (green becomes blue; red becomes green; infrared becomes red). This is not so straightforward with digital, but it can be done.
    Best,
    Helen
