Inside Shots
Discussion in 'Photography Equipment & Products' started by jmherbison, Aug 20, 2003.
  1. jmherbison
    jmherbison TPF Noob!
    Aug 20, 2003
    28
    Puerto Peñasco, Mexico
    I have a Canon Powershot G2. I am a webdesigner and have gotten into taking photos of homes for virtual tours. When I take photos inside you can not see outside. There is a bad glare on the windows and doors. Do I need a filter or is there a setting on the camera that I need to change.
    Can you also give me a good website for filters and lenses for the Powershot G2.
    Thanks,
    jmherbison
    josh@rockypoint.com.mx
  2. voodoocat
    voodoocat ))<>(( Supporting Member
    May 15, 2003
    5,277
    17
    Gilbert, AZ
    The reason you cannot see outside is because the indoors have much less light than outside. When you properly expose for the light inside, the outside is going to be overexposed a few stops.
  3. jmherbison
    Aug 20, 2003
    28
    Is there any way for me to fix it. I see shots all the time where you can see outside and see all the inside. Mine always look dark if I focus on the outside.
    Thanks,
    Jmherbison
  4. motcon
    motcon TPF Noob!
    Jul 18, 2003
    1,410
    usa. soon to be a euro boy.
    shooting interior archicture requires an extensive understanding of light.
    you must get an understanding of how many different types of light are in the room (sun, inc, fluor) as you will need to match color temps.
    you have to match the interior lighting with the window light in terms of exposure value and if you want an evenly lit room, you must make sure you evenly light it.
    [ame]http://www.amazon.com/exec/obidos/ASIN/0195019199/photonetA/103-4153230-9100627[/ame]
    as far as the glare issue; get a polarizer.
  5. voodoocat
    May 15, 2003
    5,277
    17
    Gilbert, AZ
    Another way, which would be difficult, is to do a double exposure. One with a cover over the window and a short expsure with it open. You could use window light (from windows not in the shot) so color balance wouldn't be an issue.
  6. jmherbison
    Aug 20, 2003
    28
    It actually isn't that difficult. I have done it that way but the images are just not the same as some that I have seen.
    Thanks for the advice.
    jmherbison
