International Space Station between Moon and Jupiter
Discussion in 'General Gallery' started by Garbz, Jul 14, 2009.
  1. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    Here's what happens when I can't sleep at night. Ok that's a lie. I set my alarm for this one. Astrostu you'll like this.
    The ISS rarely passes over Brisbane quite so nicely as it did this morning, and then it so far hasn't passed directly between the Moon and Jupiter, so I just had to get up and take this shot.
    I wish I had a 10mm. By the way in case you're wondering, the slow fade in of the ISS into the frame is because it left the earth shadow. The frame was started 20 seconds before the ISS was due to become visible and ended just after if left the frame edge.
    [​IMG]
    Thanks for looking.
  2. astrostu
    astrostu I shoot for the stars
    Aug 1, 2006
    676
    17
    Boulder, CO, USA
    Pretty neat! I've gotten one trail from the ISS before, but I deleted it 3 years ago (after taking it) since all it was was, well, a light trail.
    I may edit out the green lens flare from your image, but otherwise I'm not sure what else you could do.
  3. Canosonic
    Canosonic TPF Noob!
    Jan 2, 2009
    660
    Germany, Bonn
    Wow, I never ever seen one. Probably because of my location.
    I am just wondering, what would a IR filter done here....
  4. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    Yeah astrostu. I'm hanging out for a 10mm. As fantastic as the event is the image ends up a bit boring without any actual content in it.
    Canosonic the ISS makes multiple visible passes over Bonn per day ISS - Visible Passes Check out the one on the 20th That should be a good one. The IR filter wouldn't have done much here, maybe darken the sky slightly if I had a modified DSLR, but the ISS is just an object reflecting sunlight. It wouldn't look any different than any other silver object through an IR filter.
  5. HeY iTs ScOTtY
    HeY iTs ScOTtY TPF Noob!
    Jun 29, 2009
    380
    north west indiana
    coolio
