Is controlling the DOF only possible on certain lenses?
Discussion in 'Photography Beginners' Forum' started by Flower Child, Jun 27, 2009.
  1. Flower Child
    Flower Child TPF Noob!
    Oct 19, 2008
    778
    4
    Southeastern Kansas
    It seems there is no way to manually control the depth of focus with my Af-s Nikkor 18-135mm 3.5 - 5.6 lens, it just does it automatically. Are most lenses like this? Are there just certain lenses that can? I only have this one lens so I am not very knowledgable about the differences. I would appreciate any help with my question, thank you.
  2. icassell
    icassell TPF Noob!
    Jun 7, 2008
    9,893
    10
    Arizona
    Depth of field is controlled by varying your aperture. As you increase the aperture (decrease the f stop number), your depth of field will decrease. This requires putting the camera in some manual mode (either M or Aperture priority).
    Ian
  3. Flower Child
    Oct 19, 2008
    778
    4
    Southeastern Kansas
    Thank you very much for your help, it seems I was way off, haha.
  4. ann
    ann No longer a newbie, moving up!
    May 14, 2007
    4,263
    189
    DOF is also effected by the focal length of the lens, note your fstop will change as you zoom out; and by what you focus on. THE aperture is probably the main driver.
  5. icassell
    icassell TPF Noob!
    Jun 7, 2008
    9,893
    10
    Arizona
  6. Dao
    Dao No longer a newbie, moving up!
    Mar 24, 2008
    6,252
    418
    St. Louis
    Can you tell us what are you trying to accomplish? Are you trying to take a photo that all subjects in the photo are in focus? Or are you trying to create a photo in which the object is in focus and the background is blur?
  7. kundalini
    Jul 18, 2007
    13,603
    1,932
    State of Confusion
    Visual DoF in an image is also effected by the distance of lens-to-subject and the distance of subject-to-background in addition to your apeture to create certain affects. What are you trying to achieve?
  8. Samanax
    Samanax TPF Noob!
    Jan 1, 2009
    2,562
    Kaneohe, Oahu
  9. Jeff Colburn
    Jeff Colburn TPF Noob!
    Aug 6, 2007
    300
    Sedona, AZ
  10. Flower Child
    Oct 19, 2008
    778
    4
    Southeastern Kansas
    Thanks so much for each of your input. I have been taking many photos of bumble bees, and I have been getting more detail in the background than what I'm wanting, I want it much less distracting. After I read icassel's post about aperture, and it completely jogged my memory of things I have read about it.
    And since I am shooting bumble bees, I like to keep it on shutter speed priority, and the info you have given me about the distance if subject to lens was very helpful. I went out tried that and it works too.
    Notice there is a tad too much detail in the background, and this is after I have blurred the background in gimp.
    [​IMG]
    [​IMG]
  11. Dao
    Mar 24, 2008
    6,252
    418
    St. Louis
    In that case, use max aperture that your lens allow. Try to find a position that the background is further away from the subject. If you use the telephoto zoom lens, use the longer focal length and get a little closer (if possible) to the subject where you can still focus. (min focus distance)
  12. spudgunr
    spudgunr TPF Noob!
    Apr 22, 2009
    82
    NW Indiana
    I don't feel like saving and opening to try to find exif info, but shoot at your maximum aperature. Depending on lenses this may require one of your fastest shutter speeds as well. The stuff in the background may just be too close for even wide open aperature to blur the background. To blur it if that is the case you need a lens with a wider maximum aperature (for instance, 3.5 is better than 5.6. But, get a lens that goes down to 1.8 and that should really help you out).
