Is it me? or the camera?
Discussion in 'Photography Beginners' Forum' started by ssgv2, Nov 19, 2006.
  1. ssgv2
    ssgv2 TPF Noob!
    Nov 18, 2006
    25
    I've come accross this strange... Distortion should i say on a few of my picture. I dont know if it's me or the PowerShot A70 im using.
    If you look along the bottom of this pick (on the link) you might see what im talking about.
    http://imagehosted.co.uk/images/28244154.jpg
  2. Alex_B
    Aug 30, 2006
    14,491
    206
    Europe 67.51°N
    that link only says please sign in ...
  3. mysteryscribe
    mysteryscribe TPF Noob!
    Feb 1, 2006
    6,071
    in the middle of north carolina
    I agree with alex lol
  4. ssgv2
    ssgv2 TPF Noob!
    Nov 18, 2006
    25
    woops soz hold on
  5. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    There is some definite banding there...I don't think that is your fault. It could be a problem with the camera or maybe the file is corrupted.
    Format your memory card and take the batteries out of the camera. Put everything back and try some test shots.
  6. ssgv2
    ssgv2 TPF Noob!
    Nov 18, 2006
    25
    Thanks, but it also seems to flicker on my camera's screen every now and then, often in low light situations.
  7. AluminumStudios
    AluminumStudios TPF Noob!
    Oct 20, 2005
    99
    Pennsylvania
    I'm going to take a stab at this. I don't know if I'm right, but I'm going to guess you have a hardware problem, possibly a faultering connection inside your camera somewhere.
    I suspect this because I have IR modified a number of Nikon Coolpix cameras and once when I put one together I got some similar distortion. I took it apart and found that the ribbon cable that connects the CCD board to another circuit board wasn't in the whole way.
    CCD chips are analog devices (they output voltages, not bits), so if a connection isn't in solid, it can cause distortion in the voltages and electrical signals which are misread by the analog digital converter and can show up as distortion in the images.
    I'm somewhat experienced taking electronics apart and putting them back together. I took an A70 apart before and it was the biggest pain in the world, VERY difficult, so I don't recommend it at all. I also got thrown down on the floor in pain when the flash's capacitor (which I knew to avoid) gave me one hell of a shock.
    I don't suspect this is anything you can do much about.
    That's just my speculation based on experience. Good luck.
    ~Bill
