Is it possible to shoot this pic with my equipments?
Discussion in 'Beyond the Basics' started by hahastar, Oct 11, 2006.
  1. hahastar
    hahastar TPF Noob!
    Aug 12, 2006
    34
    I am trying to produce pics like this. I already have canon 350D with 50mm f/1.8 II lens, alien bees Digi Kit, sekonic flash meter, and a shooting table. Is it possible to do that with these equipments? thanks
    [​IMG]
  2. Big Mike
    Dec 16, 2003
    33,872
    1,823
    Edmonton
    I would certainly think so.
    It appears to be on a seamless white background (white paper). The light is very soft so you will have to use a diffuser (umbrella or soft-box). The main light is coming from the side and there is fill light which may be just reflected or coming from another source. This may have been shot in a light tent...but you should be able to get pretty close with just an umbrella.
  3. hahastar
    hahastar TPF Noob!
    Aug 12, 2006
    34
    thanks Mike. Do you think I need an extension tube for this kind of pic? Also i notice that the pic looks very sharp and clean.
  4. Big Mike
    Dec 16, 2003
    33,872
    1,823
    Edmonton
    Well, the 50mm F1.8 should certainly be capable of giving you shots this sharp. Use an aperture that is closed down at least a stop down from F1.8...with a tripod and studio lights, I would shoot at F8 or maybe more if you need more DOF. A tripod should be used, of course.
    You should be able to get fairly close with that lens...but even if you can't get it that close...the 350D has plenty of pixels so cropping shouldn't be a problems.
    Extension tubes are more for macro type shots...and I wouldn't call this macro.
  5. W.Smith
    W.Smith TPF Noob!
    Oct 11, 2006
    440
    Depending on the size of the object/subject you're exposing, and the distance between subject and camera, you will probably get some perspective distortion with that 50mm lens. The longer the focal length lens you use the less the perspective distortion.
  6. fmw
    fmw No longer a newbie, moving up!
    Sep 30, 2006
    3,656
    471
    I think it will be fine. The 50mm lens on a digital equates to a 75mm lens on a 35mm. It should allow him to get him back far enough.
  7. DocFrankenstein
    DocFrankenstein Clinically Insane?
    Apr 29, 2004
    1,646
    6
    I think you need a 1Ds MkII and some good L glass to solve the problem. Consumer lenses can't make good pictures.
    Just kidding. You need to diffuse the F outta the light and maybe light the background separately.
  8. hahastar
    hahastar TPF Noob!
    Aug 12, 2006
    34
    thanks a lot guys. i will give it a try.
  9. chevor161
    chevor161 TPF Noob!
    Oct 11, 2006
    I think so...and i will give it a try...thanks
  10. SaSi
    SaSi TPF Noob!
    Sep 23, 2006
    63
    In addition to the flash diffuser, you would be able to create this ample white light background using a soft box. You can build one using white styrofoam panels. Doesn't have to be pretty big, just 30x30x30 cm.
    With the softbox, you can even use the flash to bounce light to the top and let the box diffuse the light around the subject.
    The particular shot you posted appears to have the flash to the right of the camera generating a diffused shadow on the left. A flash diffuser was most likely used, which is a good thing in any case.
    Even with the camera built-in flash, you can make a diffuser by means of a plastic semi transparent plastic or paper. Or you can buy a diffuser pretty cheap.
  11. Christie Photo
    Christie Photo No longer a newbie, moving up!
    Jan 7, 2005
    7,042
    80
    Kankakee, IL
    I THINK there's two light sources on the subject. See where the shadows overlap? Probably one on the background too.
    Pete
