is there a cheap way of...
Discussion in 'Beyond the Basics' started by captain-spanky, May 18, 2004.
  1. captain-spanky
    captain-spanky TPF Noob!
    Jul 14, 2003
    751
    in a bubble in Yorkshire, UK
    taking REALLY close up pictures? My eos 1000fn just doesn't seem to get as close as i'd like... is there a way of improving the range without spending major money on new lenses?
  2. Artemis
    Artemis Just Punked Himself
    May 16, 2004
    5,313
    43
    England! w000t!
    Umm...i not sure wha u mean, but nothing less than going rly close and switching to micro mode.
    The little flower is how to make it take small things, so try that :)
  3. captain-spanky
    Jul 14, 2003
    751
    yeah i know that but with my lens (which is 28-210 vivitar thing) i have to be a few feet away to get a decent amount of focus and then it doesn't get very close... something needs to be about 10-15 cm big to fill the shot if you know what i mean? so i cant take pics of insects or tiny flowers or something without having to do something like fill the rest of shot with dof blurryness...
  4. markc
    markc TPF Noob!
    Mar 8, 2004
    4,237
    6
    Rochester, NY Velocity: Unknown
    Either a macro lens (very expensive)
    or screw on auxillary close-up lenses (a little expensive).
    They screw on to the threads on the end of a lens like filters do. You will usually see them labeled like +1, +2, +4 for various strengths. The real macro lens will do a better job, but is a lot more expensive.
  5. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    Macro mode is a digital camera option. Unfortunately not available with typical SLR lenses.
    To get close up or macro shots there are a few options. The best option is usually to get a macro lens. They are fairly expensive though. You could get a reverse mounting ring which allows you to mound one lens backward onto the front of another lens.
    For not a lot of money you can get close up filters. I think they are called diopters. They just screw into the front of the lens like any filter would. I have a set that has three...+1, +2 & +4. They can be used one at a time or stacked for extra magnification. They work pretty well but it can be hard to get clear pictures because the DOF is very, very short while using them. This is typical for most macro photography though. There are better or worse brands of close up filters...you get what you pay for. If you don't plan on making huge enlargements...you won't have to spend big bucks. My set is average I think. They are Hoya and I paid about $60 CDN for the set.
    edit: oh ya...and extension tubes. I for got to mention those. :wink:
  6. malachite
    malachite Heavily Medicated For Your Protection
    Feb 23, 2004
    975
    6
    Not in Arizona anymore
    Look for compatible extension tubes for your existing lens. They turn a normal lens into a macro lens at the expense of about 2 f/stops. And not a teleconverter, but an extension tube. Ebay always has a bunch for cheap.
  7. captain-spanky
    Jul 14, 2003
    751
    had a look for diopters and there's nothing that would work
    also had a look for extension tubes but there's only one Canon Eos compatible set available to the uk and they're £50!
    ah well.
    Thanks muchly for your help everyone, i shall keep looking.... :)
  8. voodoocat
    voodoocat ))<>(( Supporting Member
    May 15, 2003
    5,277
    17
    Gilbert, AZ
    Do your lenses not have threads? Diopters work with all lenses.
  9. markc
    markc TPF Noob!
    Mar 8, 2004
    4,237
    6
  10. captain-spanky
    Jul 14, 2003
    751
    aww thanks! you lot are so helpful :D
    sorry voodoocat, I meant i couldn't find an 67mm ones.. i guess i just wasn't looking well enough... :oops:
    Theres a set on markc's link that looks ok... bu I'll still have to save up :wink:
    and i kinda like the idea of those extension tubes... what would be the difference between the tube and diopters? any negative effects?
  11. voodoocat
    May 15, 2003
    5,277
    17
    Gilbert, AZ
    Well there is no extra glass when you use the extension tubes. It's basically moving the lens closer to the subject and away from film plane. The problem is you lose light which is an important thing when doing close up work.
  12. drlynn
    drlynn TPF Noob!
    Sep 19, 2003
    722
    In the Basement
    In addition to losing light as Voodoo suggested, you may lose autofocus capability, depending on which lens/camera you are using.
    Check your camera manual to see if it is fully compatible with extension tubes. Also, check the minimum f/stop required for autofocus to work. If you're using a lens with maximum aperture of f/4 or f/5.6 and you add an extension tube, you may cross the autofocus threshold for your camera.
