Is there a difference between getting closer and zooming in?
Discussion in 'Beyond the Basics' started by ella, Jun 9, 2004.
  1. ella
    ella TPF Noob!
    Jan 7, 2004
    26
    I have been wondering this for a while...
    Does it make a difference to the quality of your photos whether you zoom in with your camera, or whether you get closer to the object? I can't say I've ever noticed a major difference, other than I slightly less crisp image, but I can't help feeling that using the zoom is not as 'good'. Does anyone know anything about this??
    TIA!
  2. voodoocat
    voodoocat ))<>(( Supporting Member
    May 15, 2003
    5,277
    17
    Gilbert, AZ
    When you zoom you are changing the focal length of the lens. So zooming does not equal getting closer to the subject.
  3. ksmattfish
    Aug 25, 2003
    7,019
    34
    Lawrence, KS
    Your zoom lens does have a "sweet spot" where it will be sharper at a particular focal length, than at others, although the difference with any modern (post 1995) zoom will be small, and maybe not even possible to see with the unaided human eye.
    Also, there is the possibility of atmospheric issues with shots taken from a longer distance, but this has to do with what is in the air (dust, haze, humidity, temperature distortions, pollution, etc...) and not your lens.
    Camera to subject distance affects perspective, while zooming (focal length) affects angle of view and magnification.
    If you take a pic of a building with a telephoto lens, and then take another pic from the same spot with a wide angle lens, then you would be able to crop an image of the building from the center of the wide angle photo, blow it up, and it would have identical perspective as the shot taken with the telephoto lens (although image quality would decrease as the enlargement ratio goes up).
    If you shoot an pic of the building with a telephoto lens, and then move closer to get a similar composition with the wide angle lens, the perspective will change, and the images of the building will not be the same.
camera zooming in vs. moving closer
difference between zooming in and moving closer
dirrerence between taking a picture with zoom or getting closer to object
is it better to zoom in or move closer
moving closer vs zooming
what is the difference between zooming and moving closer
zoom vs moving closer
zooming in vs moving closer
zooming vs getting closer
