Is there a trick to manual focusing?
Discussion in 'Beyond the Basics' started by schumionbike, Jan 17, 2009.
  1. schumionbike
    schumionbike TPF Noob!
    Mar 9, 2007
    1,083
    Houston, Texas
    I try manual focusing a few time and I never seem to get a very sharp shot. I put the lens on manual focus and turn the focusing ring to make the subject in the picture reasonably clear and then take the picture but I ended up focusing on something else beside the subjects. So is there a trick to it or do I just need a lot more practices.
  2. tsaraleksi
    tsaraleksi No longer a newbie, moving up!
    Jun 12, 2007
    1,045
    Greencastle Indiana
    Generally speaking, DSLRs, particularly entry level to mid-range, are just very very difficult to manual focus successfully. There's no reason that you should worry about manually focusing the camera unless you are in a situation where you just can't get the AF to work right. In that case it's just a matter of practice.
  3. Overread
    May 1, 2008
    24,072
    4,172
    UK - England
    also check that your diopter is set right (look up in your manual for this) its a common problem that people don't set this right and then try manual focusing and get repeatedly soft shots.
  4. Ls3D
    Ls3D TPF Noob!
    Dec 15, 2007
    1,279
    Encinitas Cali
    You can also rock your body to pull final focus by moving the camera... got enough light? Tripod?
    -Shea
  5. RyanLilly
    RyanLilly No longer a newbie, moving up!
    Aug 27, 2007
    1,478
    8
    St. Louis, Missouri, USofA
    I would set your auto focus to the center point only. In manual focus the point will still blink when correct focus is reached.
  6. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    Yeah the trick to manual focusing is to use it when you can't autofocus anymore like in low light or when you're setting up a shot waiting for a subject to move into a focus point. Unless the autofocus doesn't work, autofocus will be faster and dead accurate every time when used properly.
    Modern SLRs are not at all designed for manual focusing and without a focusing aid like a split prism which were available in every SLR back in the day, autofocusing using the small viewfinder and a little focusing dot is like pulling teeth and works only about half of the time.
  7. schumionbike
    Mar 9, 2007
    1,083
    Houston, Texas
    Thanks for the responses guys, I have upgrade to a Nikon D40 with the kit len and the 55-200 VR. I was messing around with the manual focus with the kit lens. I figure I learn how to manual focus just in case I need to know how to use it but the results from my picture is all over the place.
  8. GeneralBenson
    GeneralBenson TPF Noob!
    Mar 28, 2008
    1,106
    18
    Boulder, CO
    Yeah auto focus sucks in low light, which really sucks, because it's hard as balls to manual focus in low light.
  9. PhilGarber
    PhilGarber TPF Noob!
    May 6, 2008
    813
    New Jersey (We don't bite)
    I agree.
    That is why they invented AF. Manual is hard.
  10. LiveWave
    LiveWave TPF Noob!
    Jan 2, 2008
    57
    Practice
  11. Katier
    Katier TPF Noob!
    Jan 14, 2009
    452
    Depth of field can help of course - if your focusing at F1.4 it'll be a whole lot harder than F22.
  12. pm63
    pm63 TPF Noob!
    Apr 23, 2007
    587
    London
    If you're using a camera from about the early 80's onwards, this isn't the case because all focusing/viewing is done with the aperture open to its widest to allow a bright image, with the iris diaphram only stopping down to what the user has selected when the shutter is released.
