is there any professional?
syoner
Hi, this is the question that How can metol be removed from clothes without giving any damage? if there is a professional(because Im an amateur in this subject) knows the solution, pls give me an answer.
Monomethyl-p-aminophenol sulfate eh?
It's a sulphite salt, so it'll probably come out using a suitable solvent. I would think water would probably do it, or failing that I would recommend perchloroethene or similar.
WEAR GLOVES!
Hope this helps.
Rob
It occurs to me that I should probably mention that some solvents can react with rubber gloves.
Take it to a dry cleaners!
Rob
In these days of paranoia you'd probably get rushed by the police investigating what you were mixing the chemicals for ... !!!
Plain hot water, run it in your washing machine with no problems.
