Is there just a quicky and easy way to get some dust off my CCD?
Discussion in 'Digital Discussion & Q&A' started by Pyrex, Aug 23, 2007.
  1. Pyrex
    Pyrex TPF Noob!
    Jan 10, 2007
    113
    My D70 has a little piece of dust that settled on the CCD, and I wanted to know if there was any easy way to get it off. The CCD is for the most part, clean, except for a single piece of dust.. I dont want to have to invest 100 bucks for a cleaning kit just to get a piece of dust off. anyone have some insight?
  2. D-50
    D-50 TPF Noob!
    Feb 15, 2006
    1,043
    New England
    There is no quick way to do this unfortunately unless you consider cloning the spot out of your photos a solution. If you try to clean it yourself without having a clean room or done it before I can almost gaurantee you will get more dust on your sensor.
  3. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    There most certainly is a quick & easy way. Do you know those bulb blowers? Take one of those and use it to blow the dust off of the sensor. I always turn the camera so that the front is facing down, so that the dust falls out.
    There is always the chance that you may stir up more dust, which may settle on the sensor...but it's an cheap and easy way.
    Also, there are several sensor cleaning products that are not that expensive.
  4. D-50
    D-50 TPF Noob!
    Feb 15, 2006
    1,043
    New England
    Thats true Mike,but I was assuming Pyrex would not want to get more dust on the sensor. If you get used to cleaning a sensor you can do it quickly and effectivly but for a first timer I give a 2% chance of not getting more dust on the sensor, I guess we all need to learn somehow.
  5. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    I use that method for the majority of my sensor cleaning...and I have yet to end up with more dust than when I started. And it is 'quick and easy'.
    Your suggestion of just cloning it out, may be the quickest and easiest...especially if it's only one spec of dust.
    Another method that I've been meaning to try...is a 'home made' sensor brush...to act like the Arctic Butterfly sensor brushes. It's just a flat artist's brush and you use something to give it an electrostatic charge (clean compressed air).
  6. Pyrex
    Pyrex TPF Noob!
    Jan 10, 2007
    113
    Damn this hobby. If you so much as look at your camera the wrong way it costs you $100 bucks. I was going to use the bulb cleaner, but theres always some naysayer out there recommending you don't. Someone give me odds destroying my CCD by modifying a plastic knife to hold a lense cleaning sheet and using a drop of cleaner. I've seen quite a few people use this method. (this is assuming that I do know how to make a clean edge for the tool). Worse comes to worse I'll end up with a new D200.
  7. Don Simon
    Don Simon TPF Noob!
    Jul 4, 2005
    2,484
    OK... even if you heed D-50's warning, what's the worst that could happen with a bulb blower? You get a bit more dust on the sensor. Not exactly the end of the world. I'd suggest giving it a try, certainly before you even think (which I would never, ever do) of putting something that was once a plastic knife near the sensor.
    Anyway I'm with Mike on this... I use the bulb blower regularly. I find the least dusty room in the house, hold the camera upside down and blow (after first squeezing the blower another way a couple of times to clear any dust that has settled in the nozzle). If I have ever put more dust on the sensor than I've taken off, it certainly hasn't shown up in my images.
  8. Pyrex
    Pyrex TPF Noob!
    Jan 10, 2007
    113
    hah, okay, I'll give it a shot. If that doesn't work I'll use a shop vac :mrgreen:
  9. chrisk121
    chrisk121 TPF Noob!
    Apr 15, 2007
    77
    Edmonton Alberta
    That really makes me think. Maybe if someone would come out with a device that uses the lens mount of the camera and sucks out the dust like a vacuum, sensor cleaning would be as easy as mounting a lens!
    If I made that, maybe I could afford a 1ds mk 3 :D
  10. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    That's a good idea...except that all the air that you suck out...has to be replaced with air rushing in. Although, a very small & soft tip on the end of a vacuum hose, would probably work well.
  11. D-50
    D-50 TPF Noob!
    Feb 15, 2006
    1,043
    New England
    Or if you create a good enough seal around the opening you'll actually be able to rip the glass right off the front of your sensor and clean it outside the camera.
  12. chrisk121
    chrisk121 TPF Noob!
    Apr 15, 2007
    77
    Edmonton Alberta
    People are scared of cleaning that piece of glass,how do you think they'd feel about ripping it off and exposing the sensor ;)
