Is this real or fake?
tecboy
San Jose, Cali, The Heart of Silicon Valley
How is the lighting and composition?
C&C Welcome!!!
Good, but could be a little better if you can light the right corner more.
Agree - I would also consider elevating the tool above and further from the background.
you have it right next to the curve of the base to the background. Move it forward further away from the background as John mentions.
Do you only have one flash to the left ?
Totally right on! It would look much better if you hot-glued a wire onto the handle, and literally elevated the tool above the background, then clone out the visible part of the wire. The degree of light fall-off on the right side also looks to be too much...too gray on the right hand side for a clean look.
that loos like a hex end; if that is important I would change the orientation of the tool and camera so that the end of the tool is seen.
My guess is fake. The anisotropy on the shaft doesn't look quite right and the grip appears to be normal mapped rather than displaced - though at the far end it appears displaced, so, idk.
Haven't seen much from your CGI stuff. How's it coming?
