ISO adjustments on film camera?
Discussion in 'Film Discussion and Q & A' started by crumpy, Mar 12, 2010.
  1. crumpy
    crumpy TPF Noob!
    Mar 12, 2010
    Hello people,
    First post! :D
    So, anyway, I am new to all this and I have a question. I know what different ISO ratings are and mean and what effect having High or low ISO films would have.
    However, what has me baffled is that my film camera has a little knob that I can turn to adjust ISO. what exactly is this adjusting? my films ISO is set, I have manually adjustable shutter speed and aperture. so what changes when I turn that little knob?
    my dad says it's just to remind you what film your using but I can't believe that...
    thanks in advance from a properly confused Crumpy
  2. Sam6644
    Sam6644 TPF Noob!
    Nov 18, 2009
    248
    Cincinnati, Ohio
    you can't change the ISO of film. The film is rated at a specific ISO and you turn the knob to that ISO to make sure you're light meter is aware of your film's light sensitivity so it can give you an accurate reading.
    You can turn the knob to push film, and meter as though you're using a higher ISO but that requires extra attention in the dark room afterwards.
    Unless you understand pushing ISO, you're dad is pretty much right- its just there to remind you whats in there.
  3. rallysman
    rallysman TPF Noob!
    Dec 17, 2009
    415
    Indiana
    This is a complete stab in the dark, but maybe it lets the camera know what film it has for auto modes.
    I really don't know for sure, but that seems to be the most logical at this point (until someone that is certain speaks up)
  4. Josh66
    Oct 31, 2007
    14,604
    1,238
    Cedar Hill, Texas
    It's so you can cheat.
    The (modern) camera reads the ISO from the film canister and sets it accordingly. You can change it though.
    Say you want to do a multiple exposure. Set the ISO to half of what it really is and your 2 shot multiple exposure will be properly exposed.
    Changing the ISO on a film camera is pretty much the same thing as changing exposure compensation on a digital camera.
    Also - some films perform better at an ISO other than the spec on the box. This lets you tweak it.
  5. ann
    ann No longer a newbie, moving up!
    May 14, 2007
    4,263
    189
    setting the ISO guides the meter to suggest options.
    it is very common for serious film uses to change the box speed to something else they have tested for and develop accordling.
    modern film is coded and if you use a cansister that isn't the meter usually defaults to an iso of 100, which indicates to the meter that this is a slower film and then the meter gives recommendations for what fstop /shutter speed will be needed for 100 speed film regardless of what the film might be.
    on many cameras you can over ride the coding by setting the ISO dial yourself.
  6. crumpy
    crumpy TPF Noob!
    Mar 12, 2010
    thanks for the quick response!
    It's a really old camera so there's no auto modes.
    but there is a really basic light meter when you look into the view finder.
    so, its just to tell my camera what film I have in there so that the meter is accurate. that makes sense. should have thought of that.
    so any camera without a light meter will not have an ISO dial?
  7. Josh66
    Oct 31, 2007
    14,604
    1,238
    Cedar Hill, Texas
    Without a meter, there would be no reason for the camera to need to know what ISO film was in it.
  8. crumpy
    crumpy TPF Noob!
    Mar 12, 2010
    sweet. thanks for clearing that up for me. was really annoying me! lol
  9. matfoster
    matfoster TPF Noob!
    Feb 12, 2010
    722
    Nuneaton, Warwickshire, UK
    for automatic cameras, this is achieved by DX encoding.
    DX encoding - Wikipedia, the free encyclopedia
  10. compur
    compur Been spending a lot of time on here!
    Mar 6, 2008
    3,040
    509
    L.A.
    Lots of older cameras without meters have an ISO dial. (Actually it was
    called an ASA dial in those days.) But, the dial on a meterless camera
    was used as a reminder or, sometimes, it linked with an optional meter
    attachment that could be mounted on the camera.
  11. djacobox372
    djacobox372 No longer a newbie, moving up!
    May 4, 2008
    2,925
    129
    Seattle, WA
    There's an iso dial on the bottom of my meter-less nikon F, but all it does is serve as a reminder as to what film I've loaded in the camera.
  12. matfoster
    matfoster TPF Noob!
    Feb 12, 2010
    722
    torn-off endflap of the film's box, slipped into the memo holder looks cool ;).
changing iso on film camera
changing iso ratings on film
film camera iso
how to adjust film camera iso
iso on film camera
iso setting for film camera
iso settings for film camera
what are iso settings for film
what film cameras need to set iso
when loading film set iso at
