ISO speed shooting
Discussion in 'Beyond the Basics' started by HoboSyke, Dec 21, 2005.
  1. HoboSyke
    HoboSyke TPF Noob!
    Jun 8, 2005
    1,052
    7
    Sydney - Australia
    Hi all.
    If im shooting fast moving sports like Skateboarding on a bright sunny day where theres enough light is ISO 100 ok to use or should I use 200 or 400 to catch the fast moving action?
    Thanks in advance.. :p
  2. photoboy15
    photoboy15 TPF Noob!
    Nov 16, 2005
    130
    If you meter says theres enought light, probably around 500th, then your ok.
  3. Rob
    Rob TPF Noob!
    Jan 29, 2005
    6,217
    134
    London
    With your 24-70 f2.8 you should be fine at 100 ISO if it's "normal" daylight.
    Rob
  4. airgunr
    airgunr TPF Noob!
    Mar 21, 2004
    846
    4
    Delavan, Wisconsin, USA
    It will also depend on the apature you select. The smaller the apature (greater the DOF) you choose the slower the shutter will be. If your shooting wide open at f2.8 then Rob is correct that you should be fine.
  5. markc
    markc TPF Noob!
    Mar 8, 2004
    4,237
    6
    Rochester, NY Velocity: Unknown
    Keep in mind that ISO doesn't really determine how well you freeze motion. It is tied to exposure with aperture and shutter speed, but it is a fast shutter speed that will keep things sharp.
    For something like this, determine what shutter speed you want, then what aperture for the DOF you want, and that will tell you what ISO to use. If the ISO is out of the range you want, you have to budge on either the aperture or shutter speed.
    For my shooting, DOF is most important, so I choose aperture first, then the slowest shutter I can get away with, and that gives me the slowest ISO I can use.
    If you are shooting something that you want to have the least noise or grain in, like a landscape, then you would pick a low ISO first, a narrow aperture for a long DOF, and then whatever shutter you get is fine. You just use a tripod.
  6. Rob
    Rob TPF Noob!
    Jan 29, 2005
    6,217
    134
    London
    It's probably worth bearing in mind that there doesn't seem to be too much difference with your camera in the ISO between 100 and 400 according to dpreview (as I recall). Actual shutter speed might be the best way to crisp up the shots if there's not too much black in the picture.
    Rob
  7. Artemis
    Artemis Just Punked Himself
    May 16, 2004
    5,313
    43
    England! w000t!
    Id just make sure its over a 500/1, the you should be ok...take a few test shots, zoom in (if its a digi) and look for blurring...make sure to zoom in though...
  8. HoboSyke
    HoboSyke TPF Noob!
    Jun 8, 2005
    1,052
    7
    Sydney - Australia
    Thanks for the suggestions guys..
