issue with camera
Discussion in 'Film Discussion and Q & A' started by DavidElliot, Apr 15, 2009.
  1. DavidElliot
    DavidElliot TPF Noob!
    Dec 19, 2008
    169
    East Lansing, MI
    I took my Pentax P3 out to take some shots since it was really nice weather out. However, after I finished a roll and was about 10 shots into my second roll, my camera stopped working. The film advance lever is limp and the shutter release isn't responding. I'm not sure what the problem is. When I press down on the shutter release, the meter works fine. However at some point, the numbers were flashing instead of a constant glow. Could it be that the batteries are dying and that's why the film advance and shutter release won't respond? Or is it something even worse like a loose element in the camera that I need to take apart and replace? Please help.
  2. compur
    compur No longer a newbie, moving up!
    Mar 6, 2008
    2,997
    497
    L.A.
    The P3 is battery-dependent. So, that would be the first thing to check by
    replacing the batteries.
  3. Katier
    Katier TPF Noob!
    Jan 14, 2009
    452
    I'd say most likely the mirror has stuck up. The light seal can become sticky over time and cause the mirror to not drop down.
    Take the lens off, and if it's stuck then knock it down gently and you should be able to advance the film ( your exposure will be fine btw ).
    On ebay there is a guy who sells complete seal kits and replacing the mirror up seal is easy.
  4. CW Jones
    CW Jones TPF Noob!
    Feb 26, 2009
    813
    Connecticut
    Replace the batteries first, then go for the mirror stuck in the up position. on my Pentax SF10 the mirror got stuck in the up position, I accidentally hit it and it came back down and fixed the camera haha
  5. EhJsNe
    EhJsNe TPF Noob!
    Nov 23, 2008
    618
    A Riverside Town by Canada
    Batteries, mirror stuck up, gear broke? Shutter dead?
  6. christopher walrath
    christopher walrath No longer a newbie, moving up!
    Mar 19, 2008
    1,265
    24
    In a darkroom far, far away...
    If the mirror is not stuck up and you can view TTL then it's the batteries. If the mirror is stuck up and you cannot view TTl then it's worst than that, the capacitor's dead, Jim.
pentax loose mirror
pentax p3 vs nikon fm10
