issue with dwg files
eshkolmarks
Hello experts,
I have a dwg file that is corrupted or encrypted and I need to fix it.
Is there any tool I can use to check the integrity of the dwg files.
If a file cannot be opened, take the following steps below or refer to threads where the same issues are already solved, moreover if nothing of these can't effective for you, make use an ultimate solution DWG Repair Toolbox
https://www.cadeverything.com/help/showthread.php/10107-Drawing-Corrupt-Cannot-Open-Cannot-Save?p=36152#post36152
https://www.talkgraphics.com/showthread.php?69134-How-to-recover-AutoCAD-DWG-file&p=517401#post517401
  • RECOVER command
    --Recovers a selected drawing file
    --If successful, open and run AUDIT command
    --Evaluates drawing integrity and possibly more error correction
    --Set system variable AUDITCTL=1 to create a report of audit results
  • RECOVERALL command (introduced in AutoCAD 2008)
    --Attached and nested xrefs are also opened, repaired, resaved, and closed
  • INSERT and EXPLODE
  • Start a new DWG with no template
    --Run INSERT and selected the corrupted drawing
    --Check the “Explode” option
Have you posed this question on an AutoCAD or engineering forum?
