Issue with Ektar
Discussion in 'Film Discussion and Q & A' started by molested_cow, Aug 29, 2009.
  1. molested_cow
    molested_cow No longer a newbie, moving up!
    Jul 3, 2004
    3,645
    469
    Here N There
    I started using Ektar 100 recently and I have issue getting the right color to show up when taking photo of the sky, deep blue type of sky.
    eg. ( power cables with sky as background)
    [​IMG]
    As you can see, the sky turns gray while the colors on the cable remains. This has happened several times, almost every time I expect it to happen, it happens irregardless of lens, aperture and shutter speed setting. I even tried using polarized filter just for the heck of it. It's not as bad as w/o the filter, but it still causes the sky color to be much less saturated than what it should be. I also tried auto color in photoshop, and the result was not good. It over corrects the color making it over saturated and became very grainy.
    The camera body I am using is Nikon F501, with Epson v700 to scan the negatives.
    So what can cause this or how can I correct the problem?
  2. bhop
    bhop No longer a newbie, moving up!
    Dec 10, 2007
    2,224
    253
    Los Angeles
    I'm guessing the scanner software is getting confused by the limited color palette and is adjusting the colors to look like this. I've had that issue with epson scan before.
  3. molested_cow
    Jul 3, 2004
    3,645
    469
    Here N There
    Any idea how I can solve the problem?
  4. Sjixxxy
    Sjixxxy TPF Noob!
    Apr 14, 2009
    109
    MN
    Stop using auto anything.
    Grab a demo version of Vuescan and follow this guide. Manully adjust your colors of the resulting scan with curves. If it is still grey, then worry about looking atthe camera/filter/film/exposure combo.
  5. Derrel
    Derrel Mr. Rain Cloud
    Jul 23, 2009
    40,511
    15,226
    USA
    I would have to second the suggestion to get a copy of Vuescan to run your scanner. It's a good application.
    "Auto" adjustments when scanning can lead to the types of drastic errors you've shown with your sky and cables example....automatic adjustments are quite often a recipe for disaster.
  6. bhop
    Dec 10, 2007
    2,224
    253
    Los Angeles
    You can also just use epsonscan, but adjust the colors manually using the sliders during the preview scan.
  7. compur
    compur Been spending a lot of time on here!
    Mar 6, 2008
    3,039
    508
    L.A.
    What color is the sky on the negs when viewed by eye?
  8. Dwig
    Dwig TPF Noob!
    Mar 11, 2009
    1,261
    Key West FL
    Seconded...
    Try things in this order:
    1. Continue using EpsonScan but use the "Professional" mode and disable any auto adjustment. Adjust colors and exposure manually. EpsonScan, when used in the full control "Professional" mode is a rather good scanning app.
    2. Try the SilverFast SE scanning software that should have come bundled with your v700. This is rather high power scanning software that allows a lot of control.
    3. Possibly try another scanning app like Vuescan.
    You probably will find that you need go no further than #1 to achieve good results. I also have a v700 with both EpsonScan and SilverFast-SE installed. I've had the occasional image "fool" EpsonScan's auto adjust function. Simply disabling it and making manual adjustments is all I've ever needed to do. Images with a massive percentage of one color will often lead auto systems astray.
  9. molested_cow
    Jul 3, 2004
    3,645
    469
    Here N There
    Alright, I rescanned it with both Epson scan and Vuescan and the color is correct this time. I guess this is what's so analog about this whole thing!
    For me, all I do with Epson scan is to get the images. The only check box I use is the ICE option which helps to get rid of dusts and scratches for convenience sake. I do everything else in photoshop instead.
    Thanks to you guys for your help! Now I got to get myself more negative sleeves....
  10. dinodan
    dinodan TPF Noob!
    Jan 21, 2007
    417
    Charleston, South Carolina, USA
    I'm really liking Ektar 100...
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
