issues with sharpness, d90
Discussion in 'Photography Beginners' Forum' started by zeppman, Sep 10, 2009.
  1. zeppman
    zeppman TPF Noob!
    Sep 2, 2009
    39
    Chicago
    Hey everyone,
    I'm a beginner, and picked up a d90 a few days ago. I just went out during my lunch break to take a few shots, and was rather disappointed with how washed out, soft and un-sharp they were. I was using aperture and shutter priority, and it was a sunny day, iso200.
    I can't upload photos at this time since I'm at work and they block that stuff. Any experts on the d90 have any tips they can provide until I can upload photos? I haven't really changed anything on the camera except shutter, aperture and iso. I tried changing the EV a few times, adjusting for what i saw in the lcd.
    Thanks.
  2. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    You will have to post some examples, preferably along with the EXIF data.
  3. zeppman
    zeppman TPF Noob!
    Sep 2, 2009
    39
    Chicago
    OK, sorry, I'll do that as soon as I get home. My other question (while I'm here) was that I chose the option to do jpeg+raw on my computer, yet the camera only gave me doubles in jpeg format. Why did I not get the NEF files?
  4. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    If you choose RAW+JPEG on the camera, then that's what you should get. Are you sure that it's giving you double JPEG files? (are you actually viewing the file types, not just the icons, which may look alike?)
  5. Plato
    Plato TPF Noob!
    Jul 11, 2009
    1,058
    United States of America
    Further, if he's looking at unprocessed RAW images, they're going to look flat.
  6. zeppman
    zeppman TPF Noob!
    Sep 2, 2009
    39
    Chicago
    Ok, the raw/jpeg thing, Yes, I'm sure that is what I selected on my camera, and when I view them on my computer, one image under that name is called a jpeg file, and the other does not have a name until I click on it, and that it names itself "File type" jpeg. They are both the exact same size on disk too, (which I know the RAW file would be larger). I have not been able to view any raw files from this camera.
    On to the pictures. I haven't done any processing, this is straight from the camera (again, I realize they are not good, that's why I'm here looking for help):
    [​IMG]
    1/1600, F5.3, iso 800, EV +.7
    [​IMG]
    1/200, F20, iso 800, EV-.7
    [​IMG]
    1/10, f36, iso 200 ev -.3
    [​IMG]
    1/400 f4.8, iso 200, ev +.3
    [​IMG]
    1/200 F8, ISO 200, +.3
  7. max3k
    max3k TPF Noob!
    Jun 11, 2009
    497
    10
    f20 f36 ISO800 in the middle of the day.....thats definitely not helping
  8. zeppman
    zeppman TPF Noob!
    Sep 2, 2009
    39
    Chicago
    yeah, i forgot that i left it on iso800..... I switched as I took more photos.
    Please, correct me if I'm wrong, but I thought large "F" number = physically smaller aperture opening, greater depth of field, less light in? ... no?
  9. Plato
    Plato TPF Noob!
    Jul 11, 2009
    1,058
    Yes, you are correct.
  10. UUilliam
    UUilliam TPF Noob!
    May 28, 2009
    1,717
    Glasgow
    yes but too high of a f number (smaller opening) will cause diffraction
    You should keep at a maximum of f 16 - f 18
    also the EV should be set to 0
    The only time you really change EV is if it is a tricky metering situation e.g. when photographing the moon, there is only a small portion of bright light so i spot meter, then dial my EV to -1.5
  11. lvcrtrs
    lvcrtrs TPF Noob!
    Dec 18, 2008
    606
    Pennsylvania
    Pg 108 in your manual - Picture Controls
    Make sure you are not set on Neutral. Try Standard or Vivid.
    Also change your sharpness setting to 7 for starters and see how you like that. It goes up to 9 but that can really be a bit much especially for people shots. You can always up it later or tweak in a photo program.
    Below is a blip from a full DPReview.
    Nikon D90 Review: 36. Conclusion: Digital Photography Review
    The image quality, whether at base ISO or the higher settings, is excellent even if it can need a bit of tweaking of the internal settings to tailor the output to specific needs. While it's understandable that Nikon would want to try to bring the processing settings into line with its more expensive cameras, it's questionable how well the rather under-sharpened default output will serve the buyers of this camera. A little more contrast and saturation improve things, without any ill effects.
  12. Dao
    Dao No longer a newbie, moving up!
    Mar 24, 2008
    6,252
    418
    St. Louis
    Maybe take the photos again at a different time. Using a circular polarizer filter may help as well.
