issues with uv filter
Discussion in 'Photography Beginners' Forum' started by rdzmzda, Jan 8, 2009.
  1. rdzmzda
    rdzmzda TPF Noob!
    Jan 26, 2008
    364
    Oklahoma
    Ok so I bought promaster uv filter and polarizer. The uv seems to be making my photos soft any ideas bad filters? they were the ones recomended by the guy at the photostore it wasnt even that cheap should i return this thing or what? im attaching a photo so you can see what i mean...also im using a lens hood would that make a difference?
    [​IMG]
    here is another one as well
    [​IMG]
  2. tirediron
    Jul 8, 2005
    40,925
    12,427
    Victoria, BC
    Okay, the only way an accurate assessment can be made is to shoot the scene twice; once with, and once without the filter and then post a couple of 100% crops, one from the centre area and at least one toward the edge of the image. That said, Promaster is simply a reseller, not a manufacturer. I would guess that they've bought a run of bottom-end Hoya or Tiffen filters, and put their name on it. Always stick with name brands. For filters go with Hoya, Tiffen, B+W, or Heliopan.
  3. OldClicker
    OldClicker TPF Noob!
    Nov 29, 2008
    194
    Mundelein, IL USA
    Do you have both on? For these shots, I don't see any reason to use either. The UV does nothing but protect the lens and the polarized filter reduces glare/reflections (which also makes the sky bluer). - TF
  4. rdzmzda
    rdzmzda TPF Noob!
    Jan 26, 2008
    364
    Oklahoma
    no i just had the uv filter on anyways i took a picture with the uv filter on and then off....here they are
    with uv filter on
    [​IMG]
    with uv filter off
    [​IMG]
    settings these were shot under is the canon 50 mm 1.8f iso 800 shutter speed 1/13 and im using a 5d body
