jcdeboever
- Joined
- Sep 5, 2015
- Messages
- 19,868
- Reaction score
- 16,081
- Location
- Michigan
- Can others edit my Photos
- Photos OK to edit
How did you process the film ? This picture has a feel of sixties in textures and contrast. Looks like Rodinal.
It is, I don't care for the developer either but I got way better results this time. I was told by an ilfolsol expert or fanwoman to prewash this way since im using well water. I like HC the best so far. I order rodinal but I am holding off at this time. Still to much agitation in my opinion. However, I'm good with the results. I'm a noob and journaling for a method. I trust this soup is not going to be my go to. I just wanted to give it an honest chanceThank you.
So you did use pretty much Ilford recommendations for development. Except for prewash. I think it is too long. and too warm. What you do may swell emulsion pushing grains apart and causing degradation of the image. It may. Prewash is only for the emulsion to get soft for easy developer absorption..And to stabilise temperature. 4 degrees is not much, but still. Agitation in prewash, beside initial tap and turn to loose air bubbles is not needed. Agitation is for equal distribution of working agents, or for speeding the development (Jobo system bases on constant agitation), or for controlling the contrast. Could be friend, could be an enemy.
I never really had have any success with Ilfosol 3. In any dilution ratio. Ilfosol 3 IMO is only good for English weather conditions, where is little sun. It is too contrasty. It is visible even in your picture.
Is this scan from the negative ?
Right. No, I use dish soap or photo flow in final wash to break the hardmessBy well water do you mean untreated ? Do you have problem with spots after drying the film ?
If photo flow helps you don"t have problem with hard water !Right. No, I use dish soap or photo flow in final wash to break the hardmessBy well water do you mean untreated ? Do you have problem with spots after drying the film ?
And than if you are using well water dump the Ilfosol, use HC110. It was made for this kind of situations, it has much more stable pH buffers.
