JPEG vs RAW (NEF)
Discussion in 'Photography Beginners' Forum' started by ericande, Nov 27, 2006.
  1. ericande
    ericande TPF Noob!
    Oct 23, 2006
    136
    Seattle
    I know that RAWs are higher quality then JPGs, but what exactly do you lose with a JPG? I mean, at a glance they appear identical. Are there certain types of details that JPGs are inferior at (skies, faces, gradients, etc)? I've been shooting in NEF+basic JPEG mode on my D50 anytime I'm planing on editing the photos but not sure if I need to.
    Also, is there a website that describes in plain english what algorithms JPEGs use? I mean, how they actually compress the data?
    Thanks...
  2. Big Mike
    Dec 16, 2003
    33,876
    1,826
    Edmonton
  3. Digital Matt
    Jan 30, 2004
    5,346
    66
    Santa Barbara, CA
    Most importantly, 4 bits of data, or 3840 levels of brightness. What does that equate to? Shadow and highlight detail that is otherwise lost in a compressed 8 bit jpg. You also lose the ability to accurately control white balance in post process.
    You can find info on raw vs jpg all over the net. Here is a good reliable resource and a good technical explanation:
    http://luminous-landscape.com/tutorials/understanding-series/u-raw-files.shtml
    Check out the entire website if you can. It's full of great info.
  4. ANDS!
    ANDS! No longer a newbie, moving up!
    Nov 14, 2006
    2,178
    Downtown
    RAW files allow for a greater level of post processing than JPEG's. RAW files altered retain their original "base" information, so that you can go in and edit them as much as you want and they will still retain their information to allow for further processing. The tradeoff is of course file size.
    I personally cant tell the difference between a RAW and a JPEG (Fine) quality picture; I would say if youre not doing "professional" work, shooting in JPEG at the highest resolution and setting (I actually shoot at JPEG large res, basic quality) should suffice.
    As for algorithims, you might be able to find that information on DPREVIEW.com - through a review of the camera they have. They sometimes have scientific info like that in the review.
  5. ericande
    ericande TPF Noob!
    Oct 23, 2006
    136
    Seattle
    good info.
    so for JPEGs, a lot of the space savings is from the reduction in possibile brightness levels, then I'm guessing that higher compression saves more space by identifying patterns and recording that? Then you lose quality from the patterns that are "close enough" to be recorded as such?
  6. Alex_B
    Aug 30, 2006
    14,491
    206
    Europe 67.51°N
    in terms of resolution i agree that the jpeg compression does not really hurt. but in terms of everything colour and light related yo udo see a strong difference once you start postprocessing. Just try to brighten up the shadows of an image which were underexposed... in RAW you will still have smooth gradients, whereas in JPEG it easily gets mucked up with visible steps in brightness gradients. And this is not really for "professionals" only ;)
  7. itoncool
    itoncool TPF Noob!
    Nov 27, 2006
    131
    Great info guys... thanks for asking ericande
    I have learning so much new information about RAW from here, before I only know I could have more option while doing RAW in photoshop...
    I'm still new in digital, for personal reason I'd rather picked my analog camera than bought a DSLR
    but, I couldn't resist D200, just have it few months ago when the price is already stable... so much to learn
  8. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    My little experience with my new camera and I already decided it's easier to just shoot jpeg providing the camera is setup properly. If I'm doing something important or I know I want to post process, or I can't get the exact exposure I need RAW provides you with some fantastic extra options to touch up a missexposed or otherwise camera miss-processed image.
  9. newrmdmike
    newrmdmike TPF Noob!
    May 8, 2006
    2,107
    it varies.
    yes raw has tons of benifits, however . . . if you get to be really good is it worth the trouble? xsight.com.au he shoots .jpg. also, i've done both and the workflow with rax is SUCH A PAIN, and takes so much more processing power.
    but then again, every little bit that makes you better we should be working for.
  10. Digital Matt
    Jan 30, 2004
    5,346
    66
    Santa Barbara, CA
    RAW is not just to correct mistakes. It gives you a higher dynamic range and lots more colors than jpg.
  11. Don Simon
    Don Simon TPF Noob!
    Jul 4, 2005
    2,484
    Hmm... maybe the RAW/Jpeg thing should be a sticky, seems to get asked almost daily.
    FWIW I do notice the difference in dynamic range in Jpeg vs Raw and the ability to fine-tune white balance later is something I wouldn't want to give up.
  12. Groupcaptainbonzo
    Groupcaptainbonzo TPF Noob!
    Nov 9, 2006
    463
    Turners Hill, West Sussex, UK.
    With RAW you gain detail (see above) but you loose a lot of space in memory. So what do YOU want?... Memory is very cheap these days, and once detail has been lost in compression it is irretrievable.. For granny on the beach JPEG is fine. Ifyou want to sell images RAW is best..
