Just built my first light box.
Discussion in 'Photography Beginners' Forum' started by Campbell, Jan 13, 2008.
  1. Campbell
    Campbell TPF Noob!
    Sep 2, 2007
    231
    Florida
    http://www.pbase.com/wlhuber/light_box_light_tent
    I was pretty intrigued by making a homemade light box just for fun, so I did a little research online and found a great site I thought I'd share. It's not like making one is very hard, but figured that people like me who think its harder than it is would get some great use out of it. I probably spent about $12 total, because I already had high-power lights and a white sheet. I spent about 10 minutes at Home Depot getting all of the PVC pipe, and it took about the same amount of time to build it.
    Here is the finished product:
    [​IMG]
    Here are my first couple of shots:
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Just thought I'd share :)
  2. KristinaS
    KristinaS TPF Noob!
    Nov 9, 2007
    424
    Pittsburgh, Pa
    Nice. Thanks for the info. I'd like to do this myself.
  3. astrostu
    astrostu Guest
    Try adjusting your white balance.
  4. RKW3
    RKW3 TPF Noob!
    Apr 30, 2007
    1,716
    So Cal
    I think if you overexpose the shot a tad the background will be more white. I'm not positive though, I have no experience with light boxes.
  5. bango707
    bango707 TPF Noob!
    Sep 23, 2007
    124
    Downtown LA
    I would pull the lights back from the sheet a few feet. In the film industry they call that 'dry humping' which basically defeats the purpose of having all of that diffusion there because its not being used effectively. When you are using any type of diffusion your light source should fill the entire diffused surface. If you look at the sheet/silk/vellum when there is a light behind it you shouldn't be able to see the light source. The whole diffusion should glow evenly with no hotspots. If you can see the light through the diffusion then back the light up till the diffusion is lit evenly.
  6. Campbell
    Campbell TPF Noob!
    Sep 2, 2007
    231
    Florida
    Thanks for the info, I didn't realize the lights were supposed to be so far back. I guess I'm going to have to find a new room to do my shooting in then.
  7. Trish1977
    Trish1977 TPF Noob!
    Nov 26, 2007
    64
    Houston, TX
    I made 2 recently - one from a cardboard box and the other from a mesh cube I found at The Container Store for $11.99 (it folds flat, so it's more portable). So far I have used tissue paper to diffuse the light, but I will try out a sheet to see if that works better.
    I have posted a photo of the mesh box here, and I also have a lot of photos taken in the 2 boxes in my stream:
    http://flickr.com/photos/trish1977/2180042166/
    Both were pretty easy to make and fun! I've loved using them so far!
  8. Campbell
    Campbell TPF Noob!
    Sep 2, 2007
    231
    Florida
    Nice setup you have there, what brand of lights are those?
  9. JoannaWilcox
    JoannaWilcox TPF Noob!
    Jan 14, 2008
    93
    Southern Ontario, Canada
    There's a great macro light box do-it-yourself how to here. I haven't tried it out yet but the results look very professional.
