Just how durable is modern flash memory?
Discussion in 'Photographic Discussions' started by Garbz, May 30, 2010.
  1. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    So there's quite a few people on this forum who advocate many smaller flash chips rather than one big one. That's all good and fine. But recently I saw something that's got me thinking of the durability of modern EEPROM flash.
    So CF cards have been run over by cars, have gone through the wash (I've personally had 2 CF cards, 1 USB stick and 1 SD card go through the wash and one CF card even made it through the drier. Nothing has died on me yet. CF cards have to be one of the most mechanically durable cards on the market save for the hundreds of pins in the socket. But they all use one underlying identical technology. They are all the same kind of flash chip.
    SD cards address the flash chip directly using I2C and so do xD cards. The memory card reader needs a controller to decide how to write to the cards. CF cards mimic an ATA interface to the flash and each chip contains its own onboard controller (this is one of the reasons for their huge size and number of pins). You can even get basic adapters that make SD cards look like a UDMA harddisk, and plug into the standard parallel interface.
    In the past this underlying flash chip has always had a limited number of writes before they break. Note that nearly every failure case is during writing and not during reading. So a dead card can nearly always be recovered (assuming the flash chip died and not the onboard controller). Early this number was often 100000 re-writes. The parts of the chips that always wore out were the file allocation tables which often get overwritten constantly during normal operation.
    Last year I looked at this the number quoted was "up to" 1000000 write operations for an EEPROM Atmel serial EEPROM chip that I used in my thesis. Looking at Microchip and Atmels website shows most newer chips have a change in wording of "at least" 1million write/erase cycles permitted.
    One of my more favourite providers of elec engineering toys Dangerous Prototypes decided to test just one of these new chips. By creating a small program that writes verifies and erases the chip over and over again and counting the number of times the verification is successful they are testing just how durable flash is.
    It looks like it's going to hit 4million write/erase cycles this week. There's a webcam which you can use to watch the device in action.
    Dangerous Prototypes Prototype: Flash_Destroyer
    So looks like it may be time to consider physical abuse being the killer of flash rather than having old cards which didn't even outlive the shutter on a camera.
  2. Newcastle Shooter
    Newcastle Shooter TPF Noob!
    Apr 4, 2010
    63
    Newcastle
    Nice post :)
    Very interesting. I tend to go for 4x 4gb CF cards - but thats due to the excellent price on sandisk extreme III's at the moment. I have not reason to not trust them though - I think alot is also to do with you get what you pay for. I feel safer with the exteme series reputation for durability and cant argue with that yet. The only time I have had a card fail on me was with a cheap ebay card - long time ago but the last time. I would only buy the good stuff now.
    Thanks for sharing :)
  3. magkelly
    magkelly TPF Noob!
    May 5, 2010
    270
    USA
    I have literally been using the same 512MB CF cards since 2003 and I've never had a lick of trouble with them. Now I don't shoot every day, but still I figure I must have used these things practically to death over 7 years. I'm about to retire them I think anyway. My camera takes 2 GB cards and they have some on Amazon for like 10 bucks now. I'd like to grab 2 at some point in the near future. I figure it's probably past time!
  4. table1349
    table1349 Been spending a lot of time on here!
    Sep 9, 2006
    4
    Cool [​IMG]
  5. KmH
    Apr 9, 2009
    40,737
    5,587
    Iowa
    4M cycles, sweet. Thanks for the link.
  6. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    IT'S DEAD
    Dangerous Prototypes Flash Destroyer wrap up
    It finally gave up. After 11,494,069 write verify erase cycles!!!!!!!
    Very very interesting analysis of the failure mode too!
    "In our test, the damaged bit continued to work over 200,000 times after the initial error. It then entered a phase of continuous, but time delayed, bit-flipping. This failure could be difficult to detect during normal use because the corruption happens only after a few seconds (or reads) have passed."
    One thing though is that this is only one sample of FLASH memory working through one interface (direct serial much like SD/xD cards but nothing like CF cards). They also mention that this is only one failure mode out of a possible many failure modes.
cf card durability
durable cf card
flash card durability
flash memory card durability
flash memory chip durability
flash memory stick durability
flash sd card portability
how reliable and durable is flash memory card
is flash memory durable
portability of flash memory card
