Justo got my 20D, need help.
Discussion in 'Beyond the Basics' started by J.Bat, Dec 24, 2008.
  1. J.Bat
    J.Bat TPF Noob!
    Mar 2, 2008
    251
    Oklahoma
    Ok I just got my 20D and I have my 50mm 1.8 For some reason the shutter speed is soooo slow. I think its on 5.6 instead of 1.8. How do I fix this problem? Is this lens ok on this body?
  2. tsaraleksi
    tsaraleksi No longer a newbie, moving up!
    Jun 12, 2007
    1,045
    Greencastle Indiana
    Just change the aperture.... it should work basically the same as on any other cameras. You might make sure that the rear wheel is turned on.
  3. J.Bat
    J.Bat TPF Noob!
    Mar 2, 2008
    251
    Oklahoma
    This may sound dumb, but how do I change the aperture?
  4. frXnz kafka
    frXnz kafka TPF Noob!
    Jul 9, 2007
    517
    Maine
    Is the aperture reading 1.8 or 5.6? If 5.6, just turn the big wheel on the back.
    If it's reading 1.8, something's wrong. Not sure how to fix that.
  5. Muay_Thai_Dan
    Muay_Thai_Dan TPF Noob!
    Nov 23, 2007
    140
    From the Ukrain to Israel to TORONTO!!
    the on/off switch- when u turn the camera on, flick the switch one notch higher to that line that points to the wheel. this will turn the wheel on, and when u turn it it will change the aperture greater or smaller respectively.
    i didnt know how to do this either when i got my 40D...but after i checked the manual i figured it out :)
    hope this helps
    -Dan
  6. JerryPH
    Oct 14, 2007
    6,111
    15
    Montreal, QC, Canada
    O..M..G.
    You got a new camera, and don't know how to change the aperture? How is that beyond the basics??
    Try reading the manual?
  7. DReali
    DReali TPF Noob!
    Oct 30, 2008
    293
    Switzerland
    Thanks Jerry, very helpful... God forbid someone on this forum is here to actually learn something...
    As dan said, when you turn it on turn the on/off swith all the way up to the line above "On". Set the camera's mode dial to manual (M) or AV mode. When in manual you can change the aperture using the big wheel at the back (also used to review your photos) and in Av mode you can use the wheel at the front (next to the shutter button) to do the same.
  8. K_Pugh
    K_Pugh No longer a newbie, moving up!
    Sep 26, 2005
    1,343
    75
    Scotland
    If this isn't a wind up then I'm Santa himself!
    You got a few folk there J.Bat lol :lol:
  9. Kendo
    Kendo TPF Noob!
    Nov 18, 2008
    87
    Marysville, CA
    Well newbies probably have no idea what Aperture means. They asked for help, not some dumb comment. Why are you so negative in most of your posts?
  10. K_Pugh
    Sep 26, 2005
    1,343
    75
    Scotland
    In all fairness the OP has posted work in the galleries, a lot in the professional galleries no less from paid work - There's no way he doesn't know what Aperture means! or how to use a camera..
    Well I hope that's the case.
  11. reg
    reg TPF Noob!
    May 28, 2008
    1,487
    Stuck inside of Mobile with the GTFO Blues Again
    Well for one this is in beyond the basics.... It would help if half the posts in here weren't the absolute most basic questions that are answered by cozying up with the manual to your shiny new $500+ camera for ten minutes.
  12. kundalini
    Jul 18, 2007
    13,608
    1,933
    State of Confusion
    Beyond the Basics
    Have you been at photography for awhile? This is the forum for more advanced discussion of photography, such as exposure methods, lighting, and other techniques and controls!
    Reading is FUNdamental.
