K200D or D40
Discussion in 'Photography Beginners' Forum' started by Knapton, Nov 30, 2008.
  1. Knapton
    Knapton TPF Noob!
    Jul 25, 2008
    6
    Ok so im planning on getting a new camera and I was kinda settled on the D40 until I saw the K200D from pentax. I am pretty new to slr's but not completly. Ive used one before and ive read up on how to use them. The thing that made me look at the pentax was that I will be shooting mostly mountain biking so it will be outdoors in the dirt,dust and rain and the pentax says it has all the seals and is waterproof/dustproof. So im wondering if its worth it to pay more money to get that than the D40 or will it be fine? Also which camera is actually better?
  2. anubis404
    anubis404 TPF Noob!
    Apr 5, 2008
    955
    When buying a camera, don't look at how the body performs as much as that you're buying into a family of lenses. Pentax has some great glass for cheap, but Nikon wins the fact that the sheer number of lenses compatible with Nikon is mind blowing.
    As for the D40 and mountain biking, don't get it. Its cheap, small, and it feels kind of like a toy. The K200D definitely wins if you're comparing the two. However, you might want to look into the D70 line. Not as beefy as the K200d, but still is durable and has twice the shutter life of the D40. Same goes with the D80, which is more comparable to the K200D.
  3. Knapton
    Knapton TPF Noob!
    Jul 25, 2008
    6
    I originaly wanted a D80 but there to much $ for me so i figured on the D40 as its like half the price. I look into some used D70 though
  4. usayit
    usayit No longer a newbie, moving up!
    Nov 15, 2003
    9,523
    345
    North New Jersey, United States of America
    Also consider that the K200D has image stabilization built into the camera. It might not be as effective as in lens IS (canon and NIkon) but since it will be available for all your lenses including early manual focus K-mounts, it is a feature that should weigh into the Pentax's favor. The Pentax also has a 10mp sensor versus the D40's 6mp sensor.
    IIRC, neither camera is weathersealed.
  5. elemental
    elemental TPF Noob!
    Feb 6, 2008
    646
    This is one way to look at it. Another is history: There are no "pre-AI" or "modified AI" Pentax lenses- any K-mount will work just fine on a K200D (barring non-Pentax K-mount lenses, like these specifically designed for automatic Ricohs). If you're willing to work with manual focus, there is an unbelievable backlog of great lenses to work with, and many are very cheap.
    I use a K100D in addition to various K-mount 35mm bodies, and I chose my Pentax over the D40. The K200D is a generation ahead, and the D40 really doesn't compare (unless, of course, you listen to those who tell you that you're no one without a Canonikon camera, which is silly). The Pentax is built more solidly, has a higher resolution sensor, and has in-body image stabilization (which means that my 50mm from the 70s has IS- something Nikon cannot offer).
    If you want a camera from Pentax that is closer to D40 specs, check out the upcoming K-m entry-level model.
  6. Ptyler22
    Ptyler22 TPF Noob!
    May 23, 2008
    789
    Massachusetts
    If it were me. I would look into the Canon Rebels. You have all the Canon lenses and you have great image quality. an XTI is just a little more than a d40, but well worth it in my opinion
  7. Knapton
    Knapton TPF Noob!
    Jul 25, 2008
    6
    im starting to look into a D70s used now since there only about 500
  8. Dubious Drewski
    Dubious Drewski TPF Noob!
    Jan 18, 2008
    909
    4
    Lethbridge, Alberta, Canada
    Between the D40 and the K200, technically the K200 wins by a long shot. But keep in mind that it uses AA batteries instead of a battery pack (Which I say is a big minus). The D70s is a good choice. Though I have a friend who is trying to sell his D70s after having bought a K20. hehe. Maybe you two should hook up.
  9. anubis404
    anubis404 TPF Noob!
    Apr 5, 2008
    955
    I bought a used D70S and it has been great so far.
    The K200D is no doubt a better body, with newer technology, a higher resolution sensor and in body IS. But, if you decide to buy Nikon, the lens family is more promising should you decide to get serious.
    I'm not saying that you cannot get serious with a Pentax setup, but keep in mind that Pentax has yet to role out a Pro level body. Once you invest in a couple of lenses, its very hard to change systems.
  10. usayit
    Nov 15, 2003
    9,523
    345
    Please define "pro level" body and how the K20D and the K10D prior does not fall into that category. Keep in mind that the TPF has a member who is a professional fashion photographer who is invested into the system.... (albeit I haven't seen him post in a while)
  11. Steph
    Steph No longer a newbie, moving up!
    Oct 18, 2006
    1,314
    Steventon, Oxfordshire, UK
    Pentax website (here) claims the K200D has a 'dust-proof, water-resistant construction', whatever that means.
  12. Dubious Drewski
    Jan 18, 2008
    909
    4
    It's the same seals that are in the K10/20 and it means you can go out in pouring rain and shoot away, like I have.
d40 vs k200d
k200d durability
k200d shutter life
k200d vs d70
k200d+shutter life
pentax k200d shutter life
