Kaleidoscoping... (addicting)
Discussion in 'Photo Themes' started by jadin, Dec 9, 2005.
  1. jadin
    jadin The Mad Hatter
    Feb 18, 2004
    1,740
    9
    Down the Rabbit Hole.
    Kaleidoscope your photos! (I use canvas size, and mirror, flip, or both) Gives them an abstract feel and is just plain fun to see how they turn out. Just might be as addicting as negativing things.
    [​IMG]
    [​IMG]
  2. LaFoto
    Feb 1, 2004
    34,813
    817
    Lower Saxony, Germany
    Dang. I can't seem to find the mirror function.
    I do find "flip horizontally" or "flip vertically" all right, but then my original only is in mirror VIEW or upside down, that's all. That is not yet kaleidoscoping! Please explain more, for a PS dummie like myself, will you? I want to get hooked on yet something else :greenpbl:
  3. jadin
    Feb 18, 2004
    1,740
    9
    Will do!
    To start off use copy on the whole image. Use canvas size to double one of the directions, (width or height). For example if you had an 800x600 image and you wanted to mirror the height, you would make it 800x1200. At the same time you could use 200 percent instead.
    Then select the new area, and paste the original image into the selection. Now you can use the flip vertically command. It should look like a mirror straight through the middle. (bottom photo)
    If you want, you can repeat the above to double the width as well and make it a rectangle (middle photo). Or you could only mirror the horizontal. Quite a few possibilities, and each can drastically change the outcome.
  4. LaFoto
    Feb 1, 2004
    34,813
    817
    I think I've got it.
    But some steps needed to be taken differently from how you described it. Could be because I am too silly.
    But I found out that,
    -after duplicating the original image (so you save that in its original version!),
    - you have to FIRST rotate it either horizontally or vertically, whatever are your plans,
    - then copy that flipped version (so that copy stays in the memory),
    - flip it back to normal,
    - then double the canvas size (new part of canvas will be grey),
    - and then paste the previously copied (flipped) version of the picture into that grey area (outlining it first, saying "paste" then).
    If you then want to make a four-fold kaleidoscope,
    - you have to flip both images,
    - copy them - this time using the "copy merged" button (so again the flipped version stays in the memory),
    - flip it back,
    - double the canvas size
    - and paste the double+flipped version in there.
    This is what I managed to get out of these steps:
    Links gone :(
    You think I got it?
    I, for my part, feel positively hooked!
  5. LaFoto
    Feb 1, 2004
    34,813
    817
    Oh yeah: quite positively hooked (oh my, what did you do???)
    Links gone :(
  6. LaFoto
    Feb 1, 2004
    34,813
    817
    The effects can be quite peculiar:
    And you can produce all sorts of versions, depending on from where you double your image in size (top or bottom, left or right):
    Links gone :(
    My! Jadin!
    What can I do to you now for hooking me so? ;)
  7. jocose
    jocose TPF Noob!
    Sep 16, 2005
    3,059
    118
    dans la pissoir
    MUST TRY THIS WHEN I GET HOME!!!!!!!!
  8. LaFoto
    Feb 1, 2004
    34,813
    817
    Don't!
    You'll be LOST!
  9. jocose
    jocose TPF Noob!
    Sep 16, 2005
    3,059
    118
    dans la pissoir
    To be lost in art
    can it be worse than haikus
    Probably it's not
    Or the limerick thread I do?
    It's worth it to be cool as you
    To try this new art
    I'm willing to start
    You're right, I'm probably through
  10. jadin
    Feb 18, 2004
    1,740
    9
    You nailed it!
    Hey, You were warned! :mrgreen:
    Links gone
  11. LaFoto
    Feb 1, 2004
    34,813
    817
    This is PURE MADNESS!
    Links gone :(
    And totally carried away :drunk:
    Link gone :(
    (I'm afraid I have even more, but now I will lean back and wait and see what others come up with :popcorn: )
  12. LaFoto
    Feb 1, 2004
    34,813
    817
    No one? OK. Away with the popcorn. More LaFoto-kaleidoscopes! (Or mirror pictures, as well):
    This one is BULGING, or so it seems:
    Link gone :(
    Only mirrored:
    Link gone :(
    Cheating, but well, at last I got a whole rainbow into "one" (erm...) picture:
    Link gone :(
    And you can do this ad infinitum, forever and ever, until you can knit your new sweater after the pattern taken from your own photos! :roll:
    Link gone :(
    (This was the original photo:
    Link gone :()
