Kalimar light meter
Discussion in 'Beyond the Basics' started by Stratman, Jan 13, 2008.
  1. Stratman
    Stratman TPF Noob!
    Jul 15, 2007
    265
    St. Louis Missouri, U S A
    My father has an old Kalimar Model 80 light meter, and it works as far as I can tell, the needle moves when you press the button, heh, I was just wondering if there is a sight where I might find a PDF of the manual for it?
    I have never used a handheld light meter, and would love to play around with it sometime.
    Thanks in advance for any help !!!
  2. jstuedle
    jstuedle No longer a newbie, moving up!
    Jun 30, 2005
    4,889
    14
    S.E. Indiana
    Depending on how old it is, I doubt it's accurate. Meter a scene with your camera, then the Kalimar. Both should be within a 1/2 stop or so.
  3. Stratman
    Stratman TPF Noob!
    Jul 15, 2007
    265
    Well, I am sure it is pretty old, probably 70's.. It uses a button cell battery, so i guess it isn't REALLY old. Problem is, I have no idea how to use it, so I can't really "try" it against my cameras meter.
  4. Mike_E
    Jan 26, 2007
    5,327
    265
    It doesn't need to be accurate as such, just consistent. If it's always 1 1/3 stop low then you can use it with confidence as long as you remember that it's low (or vice versa).
  5. bango707
    bango707 TPF Noob!
    Sep 23, 2007
    124
    Downtown LA
    That is providing that the light meter has a spot meter. The reflectance values could be totally different from the light that is falling on the subject.
    go outside midday and see what it reads. It should be around BDE (basic daylight exposure) f16 at iso 100 with a 1/100 shutter. That might be a bit off depending on where you live because of how intense the sun is there.
kalimar a-1
kalimar a-1 exposure meter
kalimar a1
kalimar exposure meter
kalimar exposure meter clip on
kalimar exposure meter model a-1
kalimar light meter
kalimar light meter manual
kalimar light meters
kalimar model 80 light meter
