Kershaw Penguin Eight 20
Discussion in 'Collector's Corner' started by rob91, Jun 20, 2008.
  1. rob91
    rob91 TPF Noob!
    Nov 3, 2007
    708
    http://licm.org.uk/livingImage/Kershaw-penguin.html
    I just came across one of these, though it didn't come with a shutter release (rod?) as you can see in the picture. Anyone familiar with fixing these, or how difficult it might be to add one myself? Thanks.
  2. rob91
    rob91 TPF Noob!
    Nov 3, 2007
    708
  3. Mitica100
    Mitica100 Moderator Staff Member Supporting Member
    Nov 11, 2003
    9,777
    50
    Ahwatukee, AZ
    The one to the right, as you look at the picture, could be the aperture control. You can adjust the aperture by moving it around the shutter. The other one could be the shutter speed? I am not very familiar w/the British cameras but I'm guessing the above.
    They're pretty easy to fix in general. You have to see if bellows are light tight, shutter works (the metal rod/plunger should be the shutter release).
  4. rob91
    rob91 TPF Noob!
    Nov 3, 2007
    708
    The problem is mine doesn't have the "plunger" to release the shutter, and I'll be damned if I can even tell where I would put a replacement rod in.
  5. compur
    compur No longer a newbie, moving up!
    Mar 6, 2008
    2,994
    497
    L.A.
    It may only have a socket for a cable release.
