kit lens bad?
Discussion in 'Commercial/Product photography' started by rabhobbes, Sep 5, 2007.
  1. rabhobbes
    rabhobbes TPF Noob!
    Aug 29, 2007
    115
    Clearwater, FL
    Hi,
    I am thinking about buying a Canon Xti for our company's product photography, is the kit lens with this body adequate, or should I definitely be looking at other lenses? As usual, I've heard conflicting recommendations on using kit lenses vs "upgrading" to another lens. Looking to keep Camera and lens budget between $1100-$1600
    (Catalog, web, and some larger printing possible)
    Thanks!
  2. Big Mike
    Dec 16, 2003
    33,843
    1,817
    Edmonton
    Welcome to the forum.
    The kit lens does get a lot of bad publicity. I own it, and it's not really as bad as it's made out to be. I think that part of the problem is that the build quality is not as good as many other lenses...and it's very light, so it feels like a toy in comparison. Remember, it's only a $100 lens...maybe the best $100 zoom lens.
    It is quite capable of taking good photos, especially when the aperture is stopped down to F8 or smaller.
    For catalog photos of still subjects, it should be more than adequate, especially if you use a tripod.
    That being said, for a few hundred dollars more, you could get a much better lens like the Canon 17-85mm IS, or the Tamron 17-50mm F2.8, for example.
  3. rabhobbes
    rabhobbes TPF Noob!
    Aug 29, 2007
    115
    Clearwater, FL
    Thanks!
  4. JamesD
    JamesD Between darkrooms
    Mar 20, 2005
    1,002
    Living in Snapshot reality.
    Will you be doing closeups of small items? If so, you might want to look at a different lens. Most of the kit lenses I've seen do not focus very close at all, and certainly not as close as a macro. You can use closeup lenses, which screw on like filters, but they tend to be a bit wanting in image quality.
  5. Big Mike
    Dec 16, 2003
    33,843
    1,817
    Edmonton
    Actually, I believe the 18-55 will focus rather close.
  6. WDodd
    WDodd TPF Noob!
    Feb 20, 2007
    899
    Amherst (Cleveland), Ohio
    Wouldn't be a terrible scenario to get the kit lens and then pick up another to give you some flexibility.
  7. jeeper
    jeeper TPF Noob!
    Sep 19, 2006
    49
    Texas
    The side of the lens says it will focus at .9 ft. (that's 10.8 inches).
  8. Big Mike
    Dec 16, 2003
    33,843
    1,817
    Edmonton
    That's not macro...but it's pretty good for some close-ups.
  9. WDodd
    WDodd TPF Noob!
    Feb 20, 2007
    899
    My 28-135 IS says Macro on it but it needs 1.6ft to focus. Whats up with that?
  10. Big Mike
    Dec 16, 2003
    33,843
    1,817
    Edmonton
    Camera companies use the word Macro like a catch phrase. Most of them aren't actually macro...which is usually determined by the actual magnification ratio it's capable of. What I call a 'true Macro' lens is capable of 1:1 magnification. That means that the size of the image on the film or sensor, is the actual size of the object.
    Canon has several macro lenses...and Macro is in the title of the lens. I'm sure they put macro on lenses like the 28-135...just for marketing purposes.
  11. jeeper
    jeeper TPF Noob!
    Sep 19, 2006
    49
    Texas
    At 135mm & set to minimum focus that probably is pretty close to 1:1. My 100mm Macro focuses at 1.02 feet, so I would imagine that 135mm would need a little extra room.
  12. fmw
    fmw No longer a newbie, moving up!
    Sep 30, 2006
    2,797
    194
    I think the application and final product would determine the quality of lens you need. I use a kit zoom lens every single day for commercial photography. But understand that it is used to make small, low-res jpeg's for use on the internet. Also it is used at f11 and the edges are always cropped off. There is simply no point in using any more lens than that for the application. No point in putting any wear and tear on a better lens for that., even though I have better lenses right there in the studio.
    If I were shooting products for posters or magazine covers, I would go a different way. Judge the equipment needs by the application.
why are kit lens bad
why kit lenses are bad
