Konica Hexanon AR 50mm F1.7
Discussion in 'Photography Equipment & Products' started by EleanorW, Aug 30, 2009.
  1. EleanorW
    EleanorW TPF Noob!
    Aug 10, 2009
    271
    Saskatoon, Saskatchewan
    Just a quick question... Does anyone know if this lens would work with Sony? All I have been able to find out about it so far is that it works with Konica Minolta cameras... and I know that Minolta lenses work with Sony.
  2. Derrel
    Derrel Mr. Rain Cloud
    Jul 23, 2009
    40,479
    15,212
    USA
    I'm afraid that the lens is not suitable for anything much except for use on the old KONICA-mount film slr cameras. It is not a Minolta A mount lens, nor a Sony Alpha mount lens, but a Konica AR bayonet mount lens.
    There is no adapter made that I am familiar with that will adapt this lens to the newer Alpha mount,and I am pretty familiar with lens adapters. The problem is two-fold: first, the Konica system AR bayonet lens system's flange-to-film register distance was very short,meaning any adapter would need a glass element to get infinity focusing, and second, the Alpha mount system uses NO external aperture ring, but instead adjusts the apertures electronically,meaning that there's no way to make a "simple" lens adapter.
    The Konica AR lens system is kind of a dead-end now as far as 35mm style d-slr body use is concerned. THERE IS ONE SOLUTION currently available, and that is to use it on a Panasonic G1 or G1H camera, which is the new Micro 4/3 format camera system. This camera system is VERY adaptable to lenses from all sorts of makers and eras. But for use on normal d-slr bodies, the Konica AR bayonet mount lenses are basically non-starters.
  3. vanax
    vanax TPF Noob!
    Dec 31, 2009
    California
    Have the E-P1 m4/3 but inherited a 1973 Konica T3 with several lenses that have bayonet mounts. I wonder if there is an adapter for the lenses for the E-P1.
    Cheers, Vanax
    The Konica AR lens system is kind of a dead-end now as far as 35mm style d-slr body use is concerned. THERE IS ONE SOLUTION currently available, and that is to use it on a Panasonic G1 or G1H camera, which is the new Micro 4/3 format camera system. This camera system is VERY adaptable to lenses from all sorts of makers and eras. But for use on normal d-slr bodies, the Konica AR bayonet mount lenses are basically non-starters.[/QUOTE]
