Lake Ontario in Snow Storm CC
Discussion in 'Photography Beginners' Forum' started by Photo Lady, Dec 29, 2009.
  1. Photo Lady
    Photo Lady No longer a newbie, moving up!
    Dec 25, 2009
    1,068
    117
    ny
    [​IMG]
  2. Photo Lady
    Dec 25, 2009
    1,068
    117
    ny
    [​IMG]
  3. TJ K
    TJ K No longer a newbie, moving up!
    Sep 9, 2008
    2,093
    Sunny South Florida
    They both seem very over exposed. The details are completely gone in them. What settings were you using?
    TJ
  4. Photo Lady
    Dec 25, 2009
    1,068
    117
    ny
    File Name: lakeontario011.jpg (rename) .jpgok cancel
    File Size: 125 kb - 799 x 531
    Camera Make: NIKON CORPORATION
    Camera Model: NIKON D5000
    Date/Time: 2009:01:11 21:32:01
    Resolution: 799 x 531
    Flash Used: No
    Focal Length: 55.0mm (35mm equivalent: 82mm...
    Exposure Time: 0.0020 s (1/500)
    Aperture: f/11.0
    ISO Equiv.: 1000
    Exposure Bias: 1.33
    Whitebalance: Manual
    Metering Mode: matrix
    Exposure: program (auto) thanks for all the help.. i set and reset the settings.. probably mixed up now... HELP!! also it was snowing heavy ... and wind was whipping... but i want decent pics ..so appreciate help..
  5. gsgary
    gsgary Been spending a lot of time on here!
    Oct 31, 2008
    16,144
    2,945
    Chesterfield UK
    Next time check your ISO setting, don't use auto because your camera is picking the wrong settings
  6. Photo Lady
    Dec 25, 2009
    1,068
    117
    ny
    thanks so much... will do...would 3,200 have been okay to use?
  7. bigtwinky
    bigtwinky No longer a newbie, moving up!
    Oct 6, 2008
    4,820
    285
    Montreal
    No, that would of been worse than ISO 1000.
    You should always aim for the lowest possible ISO setting to ensure there is no image noise. If you are getting a shutter speed that is too slow, then you need to up the ISO until its a usable shutter speed.
    Depending on how high the winds are, you could of shot this at a shutter 1/125 and had the same results, thus allowing to bring down the ISO.
  8. gsgary
    Oct 31, 2008
    16,144
    2,945
    Chesterfield UK
    The last shot you were 1/500, F11, iso1000, 55mm, if you had been at
    1/125,F11, iso400 about 3 stops lower i think it would have been closer,
    after you take a shot check your histogram if it's to the right it is over exposed
  9. Photo Lady
    Dec 25, 2009
    1,068
    117
    ny
    thanks very much... i will try this tommorrow.. probably different weather conditions.. hopefully not as rough.. yes the winds were whipping.. making it totally bad to read the camera too..
  10. Photo Lady
    Dec 25, 2009
    1,068
    117
    ny
    thanks thanks. now this gives me a foundation to work with..
  11. HikinMike
    HikinMike No longer a newbie, moving up!
    Nov 6, 2009
    1,438
    147
    Atwater, CA
    Next time, try not to crop off any tree tops. ;)
    Good luck and dress warm! [​IMG]
  12. Photo Lady
    Dec 25, 2009
    1,068
    117
    ny
    you guys are terrific... i have learned so much in such a short time... just because you open my eyes.... i am sorry that i will be here often with bad pics... but believe me it is appreciated.. i am so into this... bare with me.. and you should have seen the way i was dressed today.. i could hardly move.. but i knew that these pics lack the view i saw with my eyes of the lake and all the surrounding nature.. so glad i posted them.
