landscape of the weekend...
Discussion in 'Photography Beginners' Forum' started by lizheaemma, Sep 13, 2010.
  1. lizheaemma
    lizheaemma TPF Supporters Supporting Member
    Nov 5, 2003
    683
    38
    Canada
    C&C Welcome!
    [​IMG]
    [​IMG]
  2. Abby Rose
    Abby Rose TPF Noob!
    Feb 17, 2010
    642
    Michigan!
    #1 is nice in general, but something seems "off" about the vegetation and rocks... is it maybe two or more exposures layered? Or it could be my computer.
    #2 is a pretty scene as well but the trees are too underexposed for my liking.
  3. tirediron
    Jul 8, 2005
    41,108
    12,493
    Victoria, BC
    1. Very nice; this sis my personal favorite type of subject. I like the composition an the effect you've acheived here. I would suggest a little bit of burning on the bright area in the upper, RH corner, and some light dodging in the upper, middle area to reduce the dynamic range and the eye-grabbing light and dark areas. For some reason though, this image doesn't seem 100% sharp, but at f22, it should have been. Was this shot from a tripod?
    2. Potential, but I think you just missed. The exposure is just too extreme here. This is a tough shot, but there are a couple of ways you could have produced a much stronger image. One, by shooting several images at varying exposure for an HDR image, or two, by using a graduated neutral density filter to reduce the brightness of the sky and allow increased exposure of the lower area. In this case, fiven the shape of the clouds, I think HDR might have been the way to go.
    Just my $00.02 worth - your mileage may vary.
    ~John
  4. mooney101
    mooney101 TPF Noob!
    Oct 23, 2007
    112
    #1 One is a little soft. Also something is off about the positioning. The waterfall is to center.
    #2 Is dark but has some potential
  5. DanFinePhotography
    DanFinePhotography TPF Noob!
    Aug 13, 2010
    680
    Redmond, OR
    #1 LOOKS a bit oversaturated to me. You may be able to pull some more detail from #2 in PP if using Photoshop shadow&highlight functions
  6. lizheaemma
    Nov 5, 2003
    683
    38
    Canada
    I was having a hard time finding a good place to set up, I I was out on a rock that was about 2' square, squatting with with the tripod at lowest holding it, while a storm was blowing in, and my kids were yelling at me that we needed to start running!
    It was quite a bit better then my first attempt a few weeks ago, and my next will be even better!
    Thanks for all the comments, you are all appreciated!
  7. sovietdoc
    sovietdoc No longer a newbie, moving up!
    Jun 12, 2010
    1,140
    75
    rest of the world
    #1 looks blurry as if it was shot handheld with low shutter speed. Composition is not bad, the rock on the left is so big, throws it off a little bit.
    Second shot is great in composition but not-so-great technically. If you wanted to preserve the skies and the ground, could of tried 3-5 shot burst with exposure bracketing and then HDR merge.
