Laptop software and requirements
Discussion in 'Digital Discussion & Q&A' started by kylesmom, Apr 3, 2008.
  1. kylesmom
    kylesmom TPF Noob!
    Apr 3, 2008
    13
    Winnemucca, NV.
    I am just getting ready to purchase my first DSLR as well as the laptop and software for my photos. Any recomendations or suggestions on what I should get?:er:
  2. Hertz van Rental
    Hertz van Rental We're supposed to post photos?
    Nov 8, 2004
    16,738
    46
    Where am I now?
    Laptops are not always the best way to go - they tend to be more expensive for a lower spec. You need something with a fair bit of RAM, good processor speed and a biggish HD for Photography so you would be better off with a desktop computer to start. You would also be able to get a bigger monitor with better resolution. You can get a laptop later if you need one.
    As for software - it all depends on what level you are going to work to. Most DSLRs come with the manufacturer's software which is usually adequate for home use. Or use iPhoto on a Mac. Only buy the expensive pro software if you get to a stage where you need it.
    Although I would say that I think Photoshop is an essential tool at all levels.
  3. JimmyO
    JimmyO TPF Noob!
    Feb 3, 2008
    2,132
    NJ
    You will also have to choose between Mac and windows. Macs are easier to use, but if you have used a PC all your life it may be hard to switch over.
    But i really dont want to start a debate here, chances are you have already decided
  4. kylesmom
    kylesmom TPF Noob!
    Apr 3, 2008
    13
    Winnemucca, NV.
    what are your thoughts on the nikon d80 as well as what lenses i should get?
  5. kylesmom
    kylesmom TPF Noob!
    Apr 3, 2008
    13
    Winnemucca, NV.
    Thanks
  6. kylesmom
    kylesmom TPF Noob!
    Apr 3, 2008
    13
    Winnemucca, NV.
    Okay aren't there different versions of photoshop?
  7. Hertz van Rental
    Nov 8, 2004
    16,738
    46
    Where am I now?
    Yes.
    Getting the latest version is expensive. Older versions will work just as well for most purposes. At one time some scanners came with a free 'cut down' version of PS. And it comes in PC and Mac versions. It used to work better on a Mac (I think it started life on a Mac - though the original engine was written to do auto blue screen masking for Star Wars) but now it works well on both platforms.
    Shop around.
  8. kylesmom
    kylesmom TPF Noob!
    Apr 3, 2008
    13
    Winnemucca, NV.
    How much available RAM do I need, also processor speed, & hard drive size?
  9. kylesmom
    kylesmom TPF Noob!
    Apr 3, 2008
    13
    Winnemucca, NV.
    I am so glad you have gotten your sight back, but sorry for what has happened. I know people always say they're sorry, but I am. You see my 11 year old son was blind among several other disabilities, he passed away February 29th of this year. I decided life is so short and I've always wanted to take up photography so I am in my son's memory...it helps me deal with life without him. So thank you for being online I needed your advice.
  10. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    If you're just starting with photos the Photoshop is waay overkill. Look at something like Adobe Lightroom, and for your image editor the free GIMP program www.gimp.org would be better suited.
  11. kylesmom
    kylesmom TPF Noob!
    Apr 3, 2008
    13
    Winnemucca, NV.
    Is the Nikon D80 going to keep me from upgrading for awhile?
  12. Hertz van Rental
    Nov 8, 2004
    16,738
    46
    Where am I now?
    The more RAM you have the faster things happen with image processing - otherwise the computer/program uses part of the HD as a RAM disk and starts data swapping which slows things down.
    I would say that 2 Gig of RAM is minimum these days and, if you have the money, max it out.
    Processor speed is another control on how fast things happen - but don't be fooled into thinking that faster processor speed means faster processing. What actually limits processor speed is data bus speed. It's no good having a lightning fast processor if the data can't get in and out fast enough.
    I have an iMac running an Intel Core Duo at 2.4 GHz, 800 MHz bus and 2 Gig of RAM. It's very quick even with RAW images - and it's a bottom end Mac.
    A good sized HD (350 Gig or more) is minimum for image storage and you'll need at least one external HD for back up and archiving.
    The program you choose to manage your images will also affect how fast things happen. I was using Olympus Master but it was slow as it has to convert each RAW image to do anything. I now use Aperture and, apart from having a limitless storage and management capacity, it does auto back-up and handles most RAW formats as native. That means it is quick (images change almost as fast as you can click).
    I'm sure that you can get an equivalent set-up for PC and it'll probably be cheaper in the US. I just prefer a Mac.
