Large Format
ss2kj
Richmond, VA
Hello Again,
most of you have probably answered this question a million times. I've become interested in large format photography but have no experience. I decided to get a LF camera and start learning. What you recommend for beginners? If anyone can recommend a camera shop in richmond area it'd be great?
thanks
Setting a budget is a major consideration and don't limit your consideration to just the camera, lenses, and required accessories (meter, tripod, ...). How you will process and print the images needs to be considered as well.
At the bargin end of the scale, a used Crown Graphic with its typical 127mm lens, preferably a late model, would be a good consideration. You still need a meter, tripod, cable release, film holders and other accessories.
You then need to work out processing and printing. Lab processing is limited and expensive. With B&W, its far far better to do it yourself. B&W film processing is easy, you can do it in trays. Printing is another issue. You need an expensive enlarger and lens, a good scanner and digital printer (~$1000USD minimum), or be satisfied with 4x5 contact prints.
