- Joined
- May 1, 2008
- Messages
- 25,418
- Reaction score
- 4,999
- Location
- UK - England
- Website
- www.deviantart.com
- Can others edit my Photos
- Photos OK to edit
Has anyone any recomendations for a laser trip system for a DSLR which is not too expensive? I'm just after a simple laser trip which will also triggor the camera shutter whilst also being generally suitable for outdoor use (waterproof). I thought this would be something easy to find on ebay but I haven't had any luck so they might be lurking under a different name or somesuch.
I'd also be interested in hearing of the experiences of people if they have done a laser trip system before. I have thought that its the sort of assembly that might require (in an ideal world) more than one actual laser trip so that a variation in approach and height of subject will still triggor the laser - a single beam could be avoided by a change in approach (or an uncertain approach) for example.
I know there are the trail camera setups (which I have found on ebay) and these would be a more worthy longer term investment since they are fully sealed and far easier to setup and leave than a DSLR (which won't be abandoned far from base camp/home) and whilst their image quality would be lacking they would be better for simple observation. In there line I have seen a range (hong kong) which are nightvision equiped which has the advantages of not scaring the subject but the downside that if one does setup a DSLR (either by trip or hide) the use of a flash then would disturb the animal.
Any advice on these apporaches and the experiences of others would be most welcome - thank you
I have had the following device suggested:
Zigview S2A Kit ('7340) - Warehouse Express
Which whilst not IR based does have a motion sensor setup - however having not used one before I have no idea how sensative this motion detection is. It would be greatly limiting if I was set off by every gust of wind out there - both in positioning and also in factors such as flash battery life (a night setup will need flash to get an exposure - unless I setup with an IR DSLR and IR bulb of which I have neither )
