Learning with brightness and contrast.
Discussion in 'Photography Beginners' Forum' started by texkid, Sep 1, 2008.
  1. texkid
    texkid TPF Noob!
    Aug 26, 2008
    21
    Houston, TExAS
    I am learning little by little. Its seems that I can easily get the grass greener, by I can't get the brown to be a bit brighter.
    1. Original
    [​IMG]
    2. First Attempt (Cropped, adjusted contrast and brightness)
    [​IMG]
  2. Dubious Drewski
    Dubious Drewski TPF Noob!
    Jan 18, 2008
    909
    4
    Lethbridge, Alberta, Canada
    I'm not sure what image editing program you're using, but find out if it supports layer masks. Then use them. That's the easiest way to do what you want.
  3. texkid
    texkid TPF Noob!
    Aug 26, 2008
    21
    Houston, TExAS
    Eh...I getting closer
    [​IMG]
  4. texkid
    texkid TPF Noob!
    Aug 26, 2008
    21
    Houston, TExAS
    Not too sure what a "layer mask" is. However, I am using my friends Photoshop. Found a tool called "Quick Selection Tool". So with that, I selected the grass seperately from the dog, it made things a bit easier.
  5. floor6
    floor6 TPF Noob!
    Sep 1, 2008
    18
    [​IMG]
    levels
    curves
    red saturation +10%
    color balance: highlights/midtones +15 magenta (-15green), shadows +15green (-15 magenta)
  6. Sandspur
    Sandspur TPF Noob!
    Jan 30, 2008
    241
    Pensacola, FL
    Sorry ... regardless of whether you're using a Layer Mask or not ...
    You're starting out using the WRONG tools to make basic adjustments!
    NEVER adjust brightness and/or contrast ... or color or saturation ... until you have adjusted LEVELS first!
    Trust me. I've taught this stuff for several years. This is the single biggest mistake being made today in image management.
    http://www.jimsdigitaldiary.com/photoshop.html
    See, particularly, STEP #3.
    It's written for Photoshop Elements 4 & 5. But the steps will work for any version of PS and most other decent software.
  7. texkid
    texkid TPF Noob!
    Aug 26, 2008
    21
    Houston, TExAS
    Thank you both: Sandspur & floor6
    floor6: You got the fur the way I was trying to get. Maybe still wanted to get the grass a darker green, but I'll learn as I go through it.
    Sandspur: Thanks for the article. I looked up the definitions/use of "levels". It made more sense than adjusting brightness/contrast. I'm still reading. Maybe after class today, I'll go back to that picture, or another one, and give another go at it.
