Lens - A crash course, please!
Discussion in 'Photography Beginners' Forum' started by trillian, Oct 31, 2006.
  1. trillian
    trillian TPF Noob!
    Oct 31, 2006
    4
    Hi All,
    I just joined this forum because I have never been able to find the co-relation between mm and zoom. For example, I would like to buy the new Nikon D 80 which comes with 18-135mm AF-S DX Zoom lens. Now what type of zoom is this? 3x, 10x? How do I find this out? Is there any chart, that I can corelate too? Could someone give me crash course on lens?
    Thanks,
    Trillian
  2. dsp921
    dsp921 TPF Noob!
    Oct 20, 2005
    324
    135/18 = 7.5, it's a 7.5x zoom.
  3. trillian
    trillian TPF Noob!
    Oct 31, 2006
    4
    Thanks for that Dave, but why did you divide 135 by 18? So, 28-70 mm would be, 70/18 = 3.8x or 70/28 = 2.5x ?
  4. fmw
    fmw No longer a newbie, moving up!
    Sep 30, 2006
    3,656
    471
    It is the range of the focal lengths. Longest focal length/shortest focal length. The more extreme the zoom lens (higher X) the more compromises in design and the poorer the performance. 2X zooms are usually excellent. 10X zooms are usually (perhaps always) poor.
  5. dsp921
    dsp921 TPF Noob!
    Oct 20, 2005
    324
    The "x" zoom refers to the amount the lower number is multiplied to get to the the larger. The 28-70 would be 70/28 = 2.5, (28 x 2.5 = 70). That's where the 2.5x comes from.
    Edit: Fred got in there while I was typing...He also makes a good point regarding zoom ranges.
  6. trillian
    trillian TPF Noob!
    Oct 31, 2006
    4
    Thanks Dave and Fred for your prompt replies!!
    Trillian
  7. mentos_007
    mentos_007 The Freshmaker!
    Jun 29, 2004
    9,324
    102
    Poland, Sz-n
    but....
    what with for example 100-400 ? you have much bigger zoom with 400mm than with 100 and 400/100 = 4 ... only 4... so please do not think that 18-135mm will give you a bigger zoom than the 100-400.
  8. xfloggingkylex
    xfloggingkylex TPF Noob!
    May 5, 2006
    1,292
    Frederick, MD
    The most important thing to remember is that X zoom is all relative, and it is a measure of range more than what most people typically consider zoom (magnification).
    Like the post about, the 100-400mm is a 4x zoom but will be able to take picture from much further away than the 18-135 7.5x zoom. I hope I explained that in laymans terms.
    Also a 600mm prime lense (no zoom) will have a much tigher field of view (making things look closer) than any of the previously mentioned lenses.
  9. dsp921
    dsp921 TPF Noob!
    Oct 20, 2005
    324
    Zoom and focal length are two different things. The 18-135 will give a bigger zoom (7.5 vs. 4). It has a shorter focal length (135 vs 400) and therefore won't provide the field of view (or reach) the 400mm will. Zoom (x) is not related to focal length (mm).
  10. xfloggingkylex
    May 5, 2006
    1,292
    Frederick, MD
    reach, thats a good way to explain the focal length.
  11. fightheheathens
    fightheheathens TPF Noob!
    Aug 1, 2005
    1,011
    Berkeley
    on a full frame sensor or on film a 50 mm lens is equivalent to about what we see with the naked eye. so relative to your vision a 50 mm lens is about 1x. At 100 mm the magnification is 2x. at 150mm 3x, at 200mm 4x etc.
    ive always assumed that when someone asks how much zoom does it have they were referring to how much it magnified an image relative to what you see with your eye.
    digital sensors that are smaller have different magnification effects and to get the film equivalent you often have to multiply by 1.5 or 1.6 or something
  12. xfloggingkylex
    May 5, 2006
    1,292
    Frederick, MD
    while your idea is note worthy, when a lense is advertised as a 4x or anything like that it is more refering to the range the lense has, that is the difference between widest angle and the most telephoto angle.
    for instance an 18-55mm lense has a zoom of 3x, because 55mm is about 3 times the magnification of 18mm.
