Lens confusion
Discussion in 'Photography Equipment & Products' started by Travelamy, Oct 15, 2006.
  1. Travelamy
    Travelamy TPF Noob!
    Oct 12, 2006
    29
    I am looking in to buying a macro lens, I want the best value for my money. I prefer a little more expensive and superb than a little cheaper and less than perfect.
    I want to be able too shoot stuff like bugs, underwater macro, stuff the size of a thumbnail. And fill the screen with the shot.
    But what lens am I looking for, I have a canon 350D
    Appreciate your ideas :)
  2. fmw
    fmw No longer a newbie, moving up!
    Sep 30, 2006
    3,656
    471
    What you are not looking for is not one of the consumer lenses called "macro zoom." These are just lenses that have a close focusing range better than the zoom lenses of years ago.
    You want a true macro lens. They are available in different focal lengths providing different working distances and in zooms as well.
    A proper one would be able to produce a reproduction ratio of at least 2:1. Most will go to 1:1. That means that the image can be from 1/2 actual size on your camera frame up to full size at minimum focus. These lenses will also focus to infinity and can be used for general photography as well, understanding that they perform better optically when used up close. I'm not familiar with the Canon lens line but I'm certain there are many good options available from them. Go through the products at Calumet or B&H or whichever on line merchant you prefer and check them out.
  3. table1349
    table1349 Been spending a lot of time on here!
    Sep 9, 2006
    Can't go wrong with a Canon 100mm F2.8 marco. Simply a fantastic lens.
  4. thebeginning
    thebeginning TPF Noob!
    Jan 10, 2005
    3,795
    30
    Texas
    aside from the 100mm macro, which is VERY good (but has slow AF), check out the tamron 90mm 2.8, the canon 50mm 2.5, and the 60mm 2.8. I believe those are all 1:1 macros except for the 50 2.5, which is a 1:2 macro.
  5. DepthAfield
    DepthAfield TPF Noob!
    Feb 24, 2006
    566
    Itchycoo Park
    Have you considered extension tubes?
    I was also in the market for a decent (read: spendy) macro lens, but after a bit of ‘due diligence’ I’ve discovered that a set of extension tubes will fit my needs nicely and without breaking the bank. :wink:
  6. thebeginning
    Jan 10, 2005
    3,795
    30
    Texas
    that's a really good suggestion for someone on a budget, it completely slipped my mind. have a look at the kenko extension tube set if you're interested. it can get you VERY close for less than $200.
  7. TBaraki
    TBaraki TPF Noob!
    Jan 17, 2005
    718
    4
    Edmonton, Canada
    I can vouch for the 60mm f/2.8. I used it fairly often on a 20D. The AF was fast and the lens was very sharp. It felt fairly well constructed also.
    I don't do much close up shooting though. I'm not sure the focal length would be sufficient for shooting insects, but that might just be inexperience talking.
