Lens failure! Need Help!
Discussion in 'Photography Beginners' Forum' started by fokker, Jan 7, 2010.
  1. fokker
    fokker No longer a newbie, moving up!
    Jun 23, 2009
    2,830
    294
    New Zealand
    So I just put my EF-S 17-85mm lens onto my 40d, and got an error message saying "Err 01 Communications between the camera and lens if faulty. Clean the lens contacts."
    The contacts are clean. It only does this when the focal length is in the range of 17 to 24mm, greater than 24mm and it works fine. I can still use it in the 17-24mm range but only at the minimum aperture of f/4.
    What would cause this? I'm picking it may be a fault with a ribbon cable inside but really don't know.
    The lens is not under any sort of warranty, and I bought it second hand. What should I do?
  2. fokker
    Jun 23, 2009
    2,830
    294
    New Zealand
    Bump?
  3. Dao
    Dao No longer a newbie, moving up!
    Mar 24, 2008
    6,252
    418
    St. Louis
    Other lens works fine?
  4. fokker
    Jun 23, 2009
    2,830
    294
    New Zealand
    Yeah, its definitely the lens not the camera.
  5. telotone
    telotone TPF Noob!
    Jul 7, 2011
    Czech republic
    I have exactly the same problem. Have you been successful solving this fault?
    Thank you
  6. Ginu
    Ginu TPF Noob!
    Feb 8, 2011
    419
    22
    Vancouver BC
    Call Canon and enquire about this issue.. it seems thats a common issue.
    Some users are saying the contacts are weak and loses power... one way to fix this issue is by purchasing an aftermarket grip and use two batteries in it
  7. mozzie71
    mozzie71 TPF Noob!
    Jan 6, 2012
    18
    Melbourne
