Lens flare... again :(
Discussion in 'Photography Beginners' Forum' started by SlimPaul, Mar 9, 2009.
  1. SlimPaul
    SlimPaul TPF Noob!
    Nov 7, 2008
    437
    Hi,
    I went out to take some photos today. Unfortunately few of them got a flare on them. I work in Aperture and I tried using the retouch brush to correct the flare, but it didn't help much. Do you know any other, more reliable, way of removing lens flare?
    Thanks, Paul
    The original.
    [​IMG]
    My attempt to remove the flare.
    [​IMG]
  2. chrisburke
    chrisburke TPF Noob!
    May 25, 2007
    2,107
    Madoc, Ontario Canada
    easiest way to remove lens flare is to not shoot directly into the sun....
  3. SlimPaul
    SlimPaul TPF Noob!
    Nov 7, 2008
    437
    That was the purpose of this shot :meh:
  4. Dao
    Dao No longer a newbie, moving up!
    Mar 24, 2008
    6,252
    418
    St. Louis
    I do not know about the software Aperture. Is there a "Patch Tool" in Aperture? That may help. But of course, without trying it, I am not 100% positive.
    Just wondering, do you have a filters on your lens when the photo was taken?
  5. SlimPaul
    SlimPaul TPF Noob!
    Nov 7, 2008
    437
    I'm not sure about the patch tool. I tried cloning, but the patched area looks quite bad (as you see on the example) :/ Aren't there any programs for flare removal?
    I didn't use any filters. It's an hdr (3 images).
  6. SlimPaul
    SlimPaul TPF Noob!
    Nov 7, 2008
    437
    :cry:
  7. Dao
    Mar 24, 2008
    6,252
    418
    St. Louis
  8. Derek Zoolander
    Derek Zoolander TPF Noob!
    Dec 15, 2008
    300
    sweet picture. did you recolor it?
  9. dakkon76
    dakkon76 TPF Noob!
    Aug 22, 2007
    464
    39
    Eastern Washington
    I'm a newb, but from what I've read the best way to reduce lens flare is a multi-coated UV filter? Maybe a polarized filter would work also... but may not give you the greatest HDR composition I don't know.
  10. epp_b
    epp_b No longer a newbie, moving up!
    Aug 22, 2008
    2,135
    12
    True North Cold and Freezing
    I'm not sure what you think is the problem with the corrected photo, but I think it looks great.
    None of my lenses produce any flare, but I have uncoated filters. I just remove the filter whenever I shoot into a bright light source.
  11. AlexColeman
    AlexColeman TPF Noob!
    Dec 13, 2008
    1,732
    Did you use a hood?
  12. Jaszek
    Jaszek No longer a newbie, moving up!
    Oct 7, 2008
    2,177
    27
    Brooklyn, NY
    Ok here is my try. I can do better but I'm tired and about to go to sleep. I used the clone and patch tools. I also removed the power lines on the right.
    [​IMG]
aperture remove lens flare
gimp remove lens flare
how to get rid of lens flare in aperture
how to remove lens flare in aperture
how to remove lens flare in aperture 3
lens flare removal
remove lens flare aperture
remove lens flare aperture 3
remove lens flare gimp
removing lens flare in aperture 3
