Lens Flare :@
Discussion in 'Photography Beginners' Forum' started by AnthonyCorbo, Nov 28, 2008.
  1. AnthonyCorbo
    AnthonyCorbo TPF Noob!
    Nov 26, 2008
    60
    I just recently discovered the good and bad of lens flare. I went out about 10 minutes ago and shot a couple of a sunset from my street. They look ok but there is a horrible green shadow/ ghost like figure apearing in almost every one and after a little researching it turns out i just experienced lens flare! Woohoo. Anyways first if any one can clarify my hypothesis and second how can you avoid it, i was quite sad with the flare. I guess i'll have to learn from my mistakes hopefully with your help.:thumbup:
    ex.[​IMG]
    ( The photo is completly original, feel free to edit it if possible to rid the lens flare).
  2. chrisburke
    chrisburke TPF Noob!
    May 25, 2007
    2,107
    Madoc, Ontario Canada
    yes, its lens flare, you prevent it in 2 ways... one is dont shoot directly into the sun, and the second is, use a Lens Hood
    heres a really quick fix of the pic for you
    [​IMG]
  3. Big Mike
    Dec 16, 2003
    33,843
    1,817
    Edmonton
    Were you using an filters on your lens?
    This is often caused by light reflecting off of glass, either filters or the elements in the lens...and bouncing back toward the camera. Lenses and good quality filters often have coatings to reduce this.
    In this case, it would be easy to get rid of it with the Photoshop clone tool...or something similar.
  4. AnthonyCorbo
    Nov 26, 2008
    60
    i was using an uv filter, and i dont have photoshop can something edit it for me please?
  5. Big Mike
    Dec 16, 2003
    33,843
    1,817
    Edmonton
    It is possible to shoot into the sun without bad flare like this....and a lens hood will do nothing for you, if you are pointed at the sun anyway.
  6. Big Mike
    Dec 16, 2003
    33,843
    1,817
    Edmonton
    That's one reason I don't use UV filters.
  7. AnthonyCorbo
    Nov 26, 2008
    60
    I thought uv filter was good... what is good to use and how did you take out the flare?
  8. chrisburke
    May 25, 2007
    2,107
    simple 5 second edit with the clone tool in photoshop
  9. AnthonyCorbo
    Nov 26, 2008
    60
    is there anything in paint.net able to do that?
  10. chrisburke
    May 25, 2007
    2,107
    not familar with paint.net but i think gimp (which is a free program) has a clone tool
    http://www.gimp.org/
  11. AnthonyCorbo
    Nov 26, 2008
    60
    I have gimp too, ok thanks alot for your time and help.:D
  12. Big Mike
    Dec 16, 2003
    33,843
    1,817
    Edmonton
    Most people only use UV filters for protection...in case you drop or smash your lens, it's cheaper to replace the filter than the whole lens. But unless you use a really good quality filter, it will hurt your image quality and cause problems like this.
fixing lens flare in gimp
how to get rid of lens flare in gimp
how to get rid of lensflare in gimp
how to make a big lense flare gimp
lens flare in paint.net
paint.net fix flare
paint.net lens flare
paint.net lens flare tool
sunset lens flare gimp
where do you find lens in paint.net
