lens fog
Discussion in 'Photography Beginners' Forum' started by den9, Oct 19, 2009.
  1. den9
    den9 TPF Noob!
    Dec 8, 2007
    572
    Doylestown, PA
    went out front of my house and did a 1 hour exposure of the stars. i put my lens in a ziplock bag and left it outside in the cold for a half hour, then i took the camera out of the bag and took the shot, came back and hour later to release the shutter and the lens was fogged up. how do i keep it from fogging on long exposures (40 degrees outside)
  2. ErectedGryphon
    ErectedGryphon TPF Noob!
    Sep 9, 2009
    333
    Houston, TX
  3. Derrel
    Derrel Mr. Rain Cloud
    Jul 23, 2009
    40,232
    15,105
    USA
    I would go the absolute other way...pull the battery out of the camera,and then put the camera in the refrigerator to get good and chilled....zip the camera outside really fast,and set it up and make the exposure.
  4. ErectedGryphon
    Sep 9, 2009
    333
    Houston, TX
    You describe Cold Soaking...
    Source: Winter photography tips from Adorama Learning Center
  5. den9
    den9 TPF Noob!
    Dec 8, 2007
    572
    Doylestown, PA
    well i pretty much stuck it in the fridge when it was outside in the cold for over an hour, if i wiped the condensation off the lens would it stay off?
  6. KmH
    Apr 9, 2009
    40,523
    5,539
    Iowa
    Not if the dew point was high enough.
  7. Flash Harry
    Flash Harry No longer a newbie, moving up!
    Jun 26, 2006
    1,966
    14
    Durham, UK
    Never tried this on a lens but on a m/bike helmet visor a very small amount of washing up liquid smeared over the view area kept the fog at bay when breathing during cold weather riding, and I mean really cold, below zero. H
  8. tom123
    tom123 TPF Noob!
    Oct 18, 2009
    32
    Did you use a uv filter? If yes, is it possible that you had moisture between the lens and the filter that caused the fog. Generally speaking, when the lens is warmer or exactly as cold as the air around it, you should not get fog.
  9. den9
    den9 TPF Noob!
    Dec 8, 2007
    572
    Doylestown, PA
    if washing up liquid refers to soap that does work, i use it for my shaving mirror, i just dont think i could do that to my lens. im going to try it again tonight.
  10. KmH
    Apr 9, 2009
    40,523
    5,539
    Iowa
    Liquid dish soap specifically. One small drop applied with a lens tissue.
  11. Josh66
    Oct 31, 2007
    14,604
    1,238
    Cedar Hill, Texas
    That's almost the opposite of what you want to do.
    Set it up outside. No special precautions (except for maybe taking the battery out if it's really cold).
    Let it equalize with the ambient air temperature, then you will be fog free.
    Put it in the bag before going back inside.
