Lens for 5D2 or 1D3?
Discussion in 'Photography Equipment & Products' started by phototrek, Apr 17, 2009.
  1. phototrek
    phototrek TPF Noob!
    Mar 10, 2009
    50
    I am thinking of buying a 5D2 or 1D3 and I already have the following len's: 20/f2.8, 24-70/f2.8L, 70-200/f2.8L and the 100-400/L. Are these len's good enough or do I need to buy additional glass? What about prime glass for the 5D2? I do mostly landscape and some wildlife photos.
  2. Overread
    May 1, 2008
    24,073
    4,172
    UK - England
    Well the 5DM2 is a full frame camera - and all those lenses you list are EF lenses so they will work perfectly well on the fullframe camera - heck three of them are L rated glass and you don't get any better than that in the Canon line.
    For landscape work you should be fine I would think - though you might look for a slightly wider lens if you want - I will let landscapers suggest options.
    For wildilfe your going to notice the wider angle of view that fullframe sees and captures in your work - that 100-400mm won't feel so long as it does on a crop sensor camera body. With a camera like the 5DM2 you do have a lot of cropping capacity so you can crop your shots down - but you might also consider some longer glass - as well as some equaly long prime glass (to improve your results for cropping down). This area can get very expensive very very quickly - cheaper prime options would be the Canon 300mm f4 IS and the 400mm f5.6 and of the two (on fullframe) I would go for the 400mm even though it does not have IS.
    If you want to go more serious with things there are lenses like the Canon 300mm f2.8 IS and the Canon 400mm f2.8 IS (getting heavy now as well). And beyond that there are 500, 600 and 800mm options - all very costly - all very very good - all rather heavy too (though the 800mm is the newest and is lighter than the 600mm)
  3. JustAnEngineer
    JustAnEngineer TPF Noob!
    Apr 11, 2008
    609
    Heart of Dixie
    Have you tried any macro photography?
  4. Montana
    Montana TPF Noob!
    May 27, 2008
    1,533
    Eastern Montana
    The lenses you have are great. What focal length do you feel you are lacking? What current camera are you using?
  5. Sw1tchFX
    Sw1tchFX TPF Noob!
    May 3, 2006
    7,500
    478
    I think you're fine. You'll know if you need anything after you get the camera.
  6. Blank
    Blank TPF Noob!
    Dec 26, 2008
    130
    US
    I must have stared at this question for 15 minutes thinking of how to answer it. The link I have pasted here is one I use all the time. It is by far the best resource for Canon equipment I have found.
    Canon Digital SLR Camera and Lens Reviews at The-Digital-Picture.com
    Preferred lens' for landscape are wide angle, wildlife is anywhere from macro to 800mm.
  7. phototrek
    phototrek TPF Noob!
    Mar 10, 2009
    50
    Thanks for all who replied. I am trying to see if the glass I have now will give me sharp pictures especially with the 5D2. I heard that this camera needs the best glass like primes.
  8. anubis404
    anubis404 TPF Noob!
    Apr 5, 2008
    955
    Any L glass will give you excellent results on a full frame body. The gap between primes and zooms is quickly closing.
  9. soylentgreen
    soylentgreen TPF Noob!
    Feb 27, 2007
    735
    Miami, FL
    I do not recommend the 100-400 for the 20+ MP cameras. There are a lot of gripes about the edge resolution of this lens on the higher resolution cameras. not a problem if you crop, but nagging. I borrowed one recently for some tests and was not convinced by the 100-400's quality for the newer sensors. It just appeared soft to me, and is slow. Probably why I have not purchased one. There is some rumblings about Canon updating much of their lens line-up and the 100-400 being one of them. It being one of the older L's with a first generation IS to boot. I will hold my breathe for a 100-400 f/4L IS and 24-70 f/2.8L IS!!!
  10. Overread
    May 1, 2008
    24,073
    4,172
    UK - England
    the 100-400mm update has been in the rumour mill so long its not funny anymore. I guess Canon don't really want to risk ending up like sigma - with several superzooms having quality control issues pulling down the overall image of the company quality.
  11. howieh
    howieh TPF Noob!
    Apr 16, 2009
    24
    read Ken Rockwell's Your Camera Doesn't Matter
    I think for you, you already have a very decent line of lenses (all L series?..common man) and I think you are set for pretty much every thing.
    Just my two pennies.
  12. table1349
    table1349 Been spending a lot of time on here!
    Sep 9, 2006
    4
    Why? Well unless you like fantasy.
    The 16-35mm f2.8LII is an outstanding lens in a range you do not have covered.
