Lens Help/Question
Discussion in 'Photography Beginners' Forum' started by Birdboy08, Jan 22, 2009.
  1. Birdboy08
    Birdboy08 TPF Noob!
    Oct 20, 2008
    4
    What would be the best lens to shoot very wide skyline's? The camera would be a Canon XSi. Sorry if this is a really stupid question but I'm awful when it comes to lenses. Thanks.
  2. Ls3D
    Ls3D TPF Noob!
    Dec 15, 2007
    1,279
    Encinitas Cali
    Well the smaller numbers are the wider angles, and with your crop factor you loose a bit of frame,.. perhaps the tokina 11-16mm? (17.6 - 25.6 with a 1.6 focal multiplier) $530ish US, might be a bit high.. Do you have a budget?
    These threads usually see a lot of action so I'm sure some more informed opinions are already on the way.
    -Shea
  3. BrandonS
    BrandonS TPF Noob!
    Feb 4, 2008
    187
    Oklahoma City, OK
    Out of the reading I've done I'd recommend the Tokina 11-16 as well. I've heard it's a great lens. It's the one I plan to buy. Keep in mind I have no experience with it or other lenses below 17mm.
  4. dhilberg
    dhilberg TPF Noob!
    Jul 26, 2008
    516
    Washougal, WA
    The trick is finding it in stock. ;) It's always out of stock at B&H, Adorama, and Pro Photo Supply (my local camera shop).
    One day my beautiful Tokina 11-16mm f/2.8, I will own you...but first you need to be in stock and my finances need to be in order AT THE SAME TIME. This never seems to happen! Timing is everything!!:gah:
  5. DRoberts
    DRoberts TPF Noob!
    Apr 18, 2008
    780
    Springfield, Missouri
    Well since you didn't mention a budget...I will suggest the Canon EF 16 - 35mm f/2.8L II USM. This is one of Canon's "super wides". Can be picked up for just over $1000. Alot better quality than the Tokina. But if $$ is an issue get the Tokina.
  6. tirediron
    Jul 8, 2005
    41,108
    12,493
    Victoria, BC
    The best lens would be a prime in the 20-30mm range, and make panoramic composite images.
  7. ANDS!
    ANDS! No longer a newbie, moving up!
    Nov 14, 2006
    2,178
    Downtown
    If he is doing landscape shots, the 11-16 F/2.8 is overkill. Tokinas equally impressive 12-24MM F/4 will more than suffice and about 200 or so less.
  8. bdavis
    bdavis TPF Noob!
    Jan 14, 2009
    784
    Iowa
    Try looking on Amazon, I've had good experiences with them lately for having things in stock.
    A 12-24 would be a great choice...also,what about the Sigma 10-20?
