Lens help
Discussion in 'Photography Beginners' Forum' started by Dreamergirl, Jan 16, 2009.
  1. Dreamergirl
    Dreamergirl TPF Noob!
    Jan 15, 2009
    9
    I just bought my first camera (Canon 10D). I plan to take shots of children & family. I'll be shooting indoor and outdoor photos. I'm on a budget and can't afford the most expensive lenses right now. I just need a good versatile lens that I can use for awhile until I can buy another. What would be a good lens to start out with?
  2. Katier
    Katier TPF Noob!
    Jan 14, 2009
    452
    I assume you got a 'kit' lens with your camera. 18-55?
    That should do you for now for shorter range stuff that just leaves a zoom requirement. Now I'm not sure what the mounts are on a canon. If it was a Pentax I'd say look at a quality manual focus lens second hand. But not sure if you can do the same with Canon Digi's
  3. Dreamergirl
    Jan 15, 2009
    9
    No kit lens.
  4. Katier
    Katier TPF Noob!
    Jan 14, 2009
    452
    WOW so you just bought the bare body? Well (assuming it's doable for canon's ) I'd grab a 50mm 'prime' manual focus lens.
    Really need a canon user to say what lenses will fit though - but in general I'd be looking for 2 lenses. a 50mm ( or 18-55 zoom ) and a tele ( 70-210 up to 80-300 ).
  5. Josh66
    Oct 31, 2007
    14,604
    1,238
    Cedar Hill, Texas
    I would go with either the 50mm 1.4 or 1.8 (as budget allows)...
  6. tirediron
    Jul 8, 2005
    41,108
    12,493
    Victoria, BC
    I wouldn't suggest a prime lens as your first lens. While the 50mm is an excellent lens, it is not nearly as versatile as a mid-range zoom. The 18-55 is a decent, consumer-quality mid-range zoom, and I think you would find that much more useful as a beginning photographer than a 50mm prime. It's also inexpensive enough that when you "outgrow" it, you aren't going to be putting a lot of amount of the shelf.
  7. Josh66
    Oct 31, 2007
    14,604
    1,238
    Cedar Hill, Texas
    The only problem I have with the kit lens is that it isn't very fast - it might not be the best lens for indoors (without flash). It probably would be a more useful lens though...
  8. Jaszek
    Jaszek No longer a newbie, moving up!
    Oct 7, 2008
    2,177
    31
    Brooklyn, NY
    Or if you find a money tree you can but the 24-70mm 2.8
  9. Katier
    Katier TPF Noob!
    Jan 14, 2009
    452
    Agreed, I found that out the hard way :) - It's why 50mm manual focus primes ( at least Pentax KA fit that I use ) hold their value because people find indoors a 50mm fast lens is better than a 18-55. I only use the wider portions of my 18-55 rarely - when I am working in confined spaces - it sits at 55 most of the time.
  10. tomhooper
    tomhooper TPF Noob!
    Jun 4, 2008
    254
    Gary, Texas
    For a budget, you could get maybe a Bower flash that is dedicated to Canon and you can get 18-55 IS from Pyxis Camera on E-bay for about $125.00. This would give you some range and even though it is a rather slow lens, with the inexpensive flash you should be ok. Get a flash with a rotating head.
    This is not a bad little flash for the money.
    Bower | SFD35C Digital Flash for Canon EOS | SFD35C | B&H Photo
    Here is the lens:
    Canon 18-55mm 18-55 IS Lens New USA for Digital SLR - eBay (item 290289341160 end time Feb-13-09 12:21:21 PST)
    Might give you a temporary fix.
  11. Dreamergirl
    Jan 15, 2009
    9
    tomhooper-I'm not sure if the lens you suggested will fit my camera. I'll do some research to find out though. It's too funny that I've been checking on ebay and already had that lens you suggested on my watch list. For a beginner, I guess I'm on the right track.
    Thanks everyone for your suggestions!
  12. tomhooper
    tomhooper TPF Noob!
    Jun 4, 2008
    254
    Gary, Texas
