Lens Help
Discussion in 'Photography Equipment & Products' started by -Tatum-, Mar 2, 2006.
  1. -Tatum-
    -Tatum- TPF Noob!
    Feb 24, 2006
    50
    I am looking for a good macro lens that is sub 200 bux U.S. which i know is hard to find. I found these on Keh.com today. All seem to in good condition with good ratting. I just copied the cart lol. Which would be best buy for close macros.
    http://img139.imageshack.us/my.php?image=keh0xl.jpg
  2. DepthAfield
    DepthAfield TPF Noob!
    Feb 24, 2006
    566
    Itchycoo Park
    I’ve had good luck finding good glass on Ebay. Just a thought…
  3. crawdaddio
    crawdaddio TPF Noob!
    Dec 5, 2005
    1,157
    14
    Central IL
    I know you want it NOW, because I did. Honestly-wait, save up and buy something with some better glass. You can't find anything 'great' in that $ range. (new of course)
  4. woodsac
    woodsac TPF Noob!
    Jul 14, 2005
    5,712
    260
    In a black hole
    You really won't be happy with any of those. None are true 1:1 macros.
    If sub $200 is your budget, invest in a set of Kenko extension tubes.
  5. -Tatum-
    -Tatum- TPF Noob!
    Feb 24, 2006
    50
    So better off to get the cheap D50 kit lens (just so i HAVE a lens to work with) and then save for what? Right now this what what i am getting.
  6. markc
    markc TPF Noob!
    Mar 8, 2004
    4,237
    6
    Rochester, NY Velocity: Unknown
    I'd prefer a 50mm/f1.8 over a kit lens myself. People want the zoom, but usually don't realize how to use it right. I think the wider aperture trumps the range in focal lengths if you only have one lens.
  7. -Tatum-
    -Tatum- TPF Noob!
    Feb 24, 2006
    50
    ya i was looking at the 50mm. I like it. It is not made for digitals but i understand it will still work on a digital, but the automatic zoom will not work? is this correct?
  8. Arch
    Arch Damn You! Staff Member Supporting Member
    Jan 21, 2006
    8,487
    102
    locked in the attic
    i think you mean the auto focus, yes that does function with a dslr. I have both the kit lens and the 50mm 1.8, i do use the prime lens more now than the kit lens, but it depends what range of subjects you want to start shooting.
  9. -Tatum-
    -Tatum- TPF Noob!
    Feb 24, 2006
    50
    yes thats exactly what i meant. How well does the 50mm do on macro shots? and wide angles?
  10. Arch
    Jan 21, 2006
    8,487
    102
    locked in the attic
    If you want to do macro or close up with the 50mm you'll have to get either the magnification filters (usually come in a set of three), or extension tubes, so that you can get in closer to your subject. I believe the extension tubes have a better result as your still using the lens glass. If you want to do wide angles you'll need a wide angle lens seperatly.
  11. -Tatum-
    -Tatum- TPF Noob!
    Feb 24, 2006
    50
    ty angel
  12. Rick Mark
    Rick Mark TPF Noob!
    Mar 4, 2006
    21
    Tatum
    I highly recommend extension tubes. I've had great success with these over the years. I think a lot of people don't realize how simple they are to use. They're relatively inexpensive. The big advantage is that all you're doing is adding an empty tube between the camera and your regular lens; since there's no glass, you don't degrade the image or lose any light. They're terrific for macro work.
