Lens hood cutting off corners
Discussion in 'Photography Equipment & Products' started by MostlyDigital, Apr 12, 2007.
  1. MostlyDigital
    MostlyDigital TPF Noob!
    Feb 9, 2005
    164
    New Jersey
    My tulip lens hood is actully being photographed in the corners to some of my picures. Lens in the canon 18-55 being used on the 30D. Does anyone know why? :(
  2. shorty6049
    shorty6049 TPF Noob!
    Mar 8, 2007
    1,906
    Minnesota
    are you using any filters?
  3. dinodan
    dinodan TPF Noob!
    Jan 21, 2007
    417
    Charleston, South Carolina, USA
    Make sure that the hood is on right. The longer "petals" should be at the top and bottom (long side) of the frame, and the shorter ones at the sides. Also, make sure that you have the bayonet latch engaged all the way.
  4. Sw1tchFX
    Sw1tchFX TPF Noob!
    May 3, 2006
    7,500
    478
    not every lens hood is the petal shape, and not every hood is a bayoneted.
    I have problems like that with the rubber screw mount hoods on my 35-70 if i'm working on 35mm. You need a smaller hood and I suggest you use the Canon hoods made for their lenses, not the generic rubber or plastic ones. But than again, Canon also charges in upwards of $500 for some of their plastic hoods.
  5. JIP
    JIP No longer a newbie, moving up!
    Aug 29, 2006
    3,019
    Pittsburgh PA
    Is the hood made for the lens?. With wide-angle lenses especially it is very important to have the proper lens hood as vignetting is an issue.
  6. MostlyDigital
    Feb 9, 2005
    164
    New Jersey
    Nope, no filters.
    Yep the big petals are at the top, when I start out, but when I focus sometimes they move. I do not know what that latch is you speak of.
    I got the hood on ebay for 10 bucks. Do'h. Maybe it doesnt fit my lens? Damn I was so excited to get the hood too. :( Does each lens have a specific hood?
  7. MPowerM3
    MPowerM3 TPF Noob!
    Mar 19, 2006
    239
    Ct, USA
    You got the wrong hood. It shouldnt be a pedal hood. Reason being is that the focusing is done through the front most part of the lens, not inside the lens as some other lens do. The Canon part number should be EW-60C. Shouldnt be more then 20 bucks from BandH or the like. If you cant find one, i'll never shoot with my stock lens again, drop me a line, I might part with it.
  8. xfloggingkylex
    xfloggingkylex TPF Noob!
    May 5, 2006
    1,292
    Frederick, MD
    its more of a problem for wider lenses
  9. Big Mike
    Dec 16, 2003
    33,852
    1,817
    Edmonton
    MPowerM3 got it right...you have the wrong hood for that lens. Petal hoods are for lenses that don't rotate when focusing.
17-35 lens hood dark edges
cutting lens hood
does a lense hood make dark edges
how does promaster lens hood work
how to fit pro master lense hood
how to install tulip hood
how to install tulip lens hood
lens hood black corner
lens hood edges
tulip nikon lense hood installation
